KARMANN
oil presure
ok,the oil presure light keeps coming on in my 1.8 16v.comes on when i get to around 3k rpm.iv drain it and changed the oil it still comes on.dad says he disconected the wires on top of the filter housing and started it and it still came on,any suggestions cheers.everything else is running fine no overheating etc.
There's a load of sensors on the gearbox end of the head on a KR (1.8 16V) engine. It's possible that one of these has lost it's wire, become faulty or that the terminal has snapped off one of them :roll:
It's also possible, as andycowuk says, that the oil pump's gone... :shock:
Check the sensors first... I'll have a look at my KR haynes manual (passat!) when I get home and let you know which sensors you should be looking for... 8)
cheers guys,already checked the top of filter housing its ok.forgot to metion that it was overheating but got that sorted them the oil pressure prob started,spoke to couple of mechanics today they recon its just a faulty sensor as the enigine got soked with water.
