MK1Campaign
Door hinge pins
Loosen the top hinge bolt and shim it up. Your hinge will still have play but the door will close properly. I did this on mine and a few others on here. Takes about 5 mins.
Dave
Dave
I take it you mean put some washers on the bolt?
Dave
You can use washers but the thickness needs to be right or the door will lift too high and you won't be any better off. I made some thin shims at work - pic attached.
