barryarginnraddo 0 Posted March 17, 2008 Hi i have seen a number of bump strip-less raddo's whilst browsing the net, trying to find inspiration of how to make my super low budget beast look better, and cleaner. are these bump strips drilled / riveted on to the pannels or are they just stuck? my car is an m reg 2.0 16v. any sugestions appreciated Ollie Quote Share this post Link to post Share on other sites
Walesy 0 Posted March 17, 2008 Hi mate, you'll find that alot of subjects have been covered before if you use the search - there's masses of information on here :) Bumpstrips are just stuck on so usually come off fairly easily with a bit of heat (perhaps a hairdryer) and a scraper. Get some tar and glue remover for getting the residue thats left off. Beware though, alot of rados have had paint and removing the bumpstrips can reveal hidden nasties. Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted March 17, 2008 and....welcome to the CF :wave: Quote Share this post Link to post Share on other sites
tedman 0 Posted May 27, 2008 i poured a kettle of boiling water over mine and they came off in one hit,not any glue left!! :clap: Quote Share this post Link to post Share on other sites
lj16v 0 Posted May 27, 2008 welcome welcome :D i took mine off with plenty of heat to melt the adhesive (used a hair dryer). Start from one end, heat a bit then gently pull back (may need something like a plastic scraper just to get it going or maybe something like a cheese wire) then heat the next section and pull etc etc. just go slowly. Then clean the glue residue off, lots of products out there. Give it a polish and hey looks loads better!!! as said above though, the strip could hide a join line if your car has had bits of paint in the past.... Quote Share this post Link to post Share on other sites
dubcharger 0 Posted May 29, 2008 where do you get the sticky strips from to put them back on again?? Quote Share this post Link to post Share on other sites
IrishG60 0 Posted May 29, 2008 I like the bump strips.. am I the only one? Quote Share this post Link to post Share on other sites
Guest Posted May 29, 2008 I like the bump strips.. am I the only one? Nope me and kip love them on ours too :luvlove: Quote Share this post Link to post Share on other sites
cdem 0 Posted May 30, 2008 Im leaving mine on aswel. They break up the colour as my cars white with black alloys Quote Share this post Link to post Share on other sites
dinkus 10 Posted June 2, 2008 You can get most of them new from VW but not all of them. They're also scarily expensive. As they do just stick on, you can get some trim-tape from Halfords and re-attach them. They tend to curl up a bit when you pull them off though, so could be a bit tricky. Quote Share this post Link to post Share on other sites
-Neil- 0 Posted November 18, 2008 You can get most of them new from VW but not all of them. They're also scarily expensive. As they do just stick on, you can get some trim-tape from Halfords and re-attach them. They tend to curl up a bit when you pull them off though, so could be a bit tricky. I need to stick one whole side of my cars bump strips back on, Does this tape from halfords have to be some really strong stuff? Is it slightly padded or is it like stelotape thin? Thanks for your help. Quote Share this post Link to post Share on other sites
Walesy 0 Posted November 18, 2008 It's padded slightly Quote Share this post Link to post Share on other sites
coolrado 0 Posted November 18, 2008 If your trims went all curvey when you removed them, leave them on top of something flat on top of a hot radiator and they will relax back to normal. The halfords double sided foam tape (with the green backing) or 3M double sided trim tape are ideal for the side trims. I have never understood why bodyshops paint around the side trims, it takes twice as much effort to mask them off and paint around them than it takes to remove them. Quote Share this post Link to post Share on other sites
cdem 0 Posted November 18, 2008 I took mine off in the end, much smoother look! Quote Share this post Link to post Share on other sites
-Neil- 0 Posted November 18, 2008 I took mine off in the end, much smoother look! Yeah i tried that, but for some reason the last person GLUED them on so some paint has come off, so i want to put them back on. Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted November 18, 2008 Im torn between taking them off and leaving them on. I love the look of the car more when the trim has been taken off. But i couldnt park the car in a car park and relax. I know they wont ALWAYS protect from idiots knocking their door onto mine. But im sure they've stopped some twit denting the car on some occassions. Quote Share this post Link to post Share on other sites
joinerboy 0 Posted December 5, 2008 what would anybody recommend to remove the sticky residue left behind after i took off the bump strips? id prefer to use something that has worked for you guys rater than mess up the paint Quote Share this post Link to post Share on other sites
Walesy 0 Posted December 5, 2008 I use this stuff mate - http://www.theultimatefinish.co.uk/Stor ... 3godXAPCjA Quote Share this post Link to post Share on other sites
-Neil- 0 Posted December 6, 2008 Im torn between taking them off and leaving them on. I love the look of the car more when the trim has been taken off. But i couldnt park the car in a car park and relax. I know they wont ALWAYS protect from idiots knocking their door onto mine. But im sure they've stopped some twit denting the car on some occassions. only problem is, that as soon as you lower your corrado (not sure if you have or not, i have) you then move the bump strip lower to the ground so if someone is going to open their door inot your car, they'll hit the ridge of the door, not the strip! Quote Share this post Link to post Share on other sites
joinerboy 0 Posted December 6, 2008 i agree with -Neil-. iv got a fiat which im running around in at the moment and all the dents on the doors are above where the bump strips are on the corrado are anyway. as the car is so low i dont think the bumpstrips help that much. just park in plenty of space and walk a little further Quote Share this post Link to post Share on other sites
