was8v 0 Posted May 15, 2008 tedman said: not noticed a huge difference in performance just the noise!! It has been proved elsewhere on here on a dyno that "open" cone / foam filters slightly reduce performance on a VR6 by taking air from around the hot engine. The stock airbox takes cooler, more dense air from just behind the headlight. The only induction kit with a proven performance increase over stock is the BMC CDA which is a closed airbox and takes air from the stock location. The differences are very small however - and the noise may more than make up for it! Quote Share this post Link to post Share on other sites
tedman 0 Posted May 15, 2008 was8v said: tedman said: not noticed a huge difference in performance just the noise!! It has been proved elsewhere on here on a dyno that "open" cone / foam filters slightly reduce performance on a VR6 by taking air from around the hot engine. The stock airbox takes cooler, more dense air from just behind the headlight. The only induction kit with a proven performance increase over stock is the BMC CDA which is a closed airbox and takes air from the stock location. The differences are very small however - and the noise may more than make up for it! cheers mate yer i only got it for the noise when funds allow the k&n will make way for a charger as the car is not quick enough for me :D Quote Share this post Link to post Share on other sites
was8v 0 Posted May 15, 2008 tedman said: yer i only got it for the noise when funds allow the k&n will make way for a charger as the car is not quick enough for me :D Should give a fairly big increase in power when used in conjunction with a charger! :D Quote Share this post Link to post Share on other sites
tedman 0 Posted May 16, 2008 was8v said: tedman said: yer i only got it for the noise when funds allow the k&n will make way for a charger as the car is not quick enough for me :D Should give a fairly big increase in power when used in conjunction with a charger! :D yer thats what i ment to say :wink: :D Quote Share this post Link to post Share on other sites
h51mon 0 Posted May 19, 2008 Nice motor mate .Don't see many Ice V.Did you buy it off pistonheads from Wales by any chance.. Quote Share this post Link to post Share on other sites
tedman 0 Posted May 20, 2008 h51mon said: Nice motor mate .Don't see many Ice V.Did you buy it off pistonheads from Wales by any chance.. cheers mate , no it wasn't from wales but i think i remember the car your thinking of . also decided to rip the rub strips off, looks much better. only took 10 mins a side as i just poured a kettle of boiling water over them and they came straight off :clap: the passenger side is unmarked but you can see where the cars had some paint on the drivers side :| terry Quote Share this post Link to post Share on other sites
tedman 0 Posted June 4, 2008 finally got the weitec's on ,very happy to say the least ! the ride quality is brilliant so much better than my old g60 on coilovers Quote Share this post Link to post Share on other sites
mattnorgrove 0 Posted June 4, 2008 Looks cracking now mate! Is that 40mm off? Any rubbing? Considering polished comps for mine, prob gonna save for BBS RX though. I did the Aero conversion on mine, what a difference that makes on a rainy motorway! (Just fitted a retrofit one on the rear too, which tidies it up nicely) Quote Share this post Link to post Share on other sites
tedman 0 Posted June 4, 2008 mattnorgrove said: Looks cracking now mate! Is that 40mm off? Any rubbing? Considering polished comps for mine, prob gonna save for BBS RX though. I did the Aero conversion on mine, what a difference that makes on a rainy motorway! (Just fitted a retrofit one on the rear too, which tidies it up nicely) cheers mate , yer 40mm no rubbing :clap: my wipers were a safety issue before i fitted the lupo wipers! bbs rx will look great on yours i was after a set when the tt rims came up terry Quote Share this post Link to post Share on other sites
ADZ_VR6 0 Posted June 4, 2008 Looks miles better now pal just right and not stupidley low :clap: Quote Share this post Link to post Share on other sites
tedman 0 Posted June 4, 2008 ADZ_VR6 said: Looks miles better now pal just right and not stupidley low :clap: thanks . very happy with the height :D ,even if it was on coilovers i would have it the same height! Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted June 4, 2008 Looking good my man :D Yeah the side protection strips are a common repainting edge to use. I colour coded mine and put them back on for that reason! Quote Share this post Link to post Share on other sites
tedman 0 Posted June 10, 2008 Took some better pic's..... Quote Share this post Link to post Share on other sites
faz 0 Posted June 13, 2008 loving it... Looking good... I do miss it ! Quote Share this post Link to post Share on other sites
tedman 0 Posted August 2, 2008 just a little update.. spent a few hours on the car last weekend and got a few jobs sorted [engine mount etc] and felt pretty happy with myself when in true corrado fashion the headlight switch shorts out burning out a wire on the loom and causing smoke everywhere! :bad-words: .went to the stealers and got a new switch[now i know where they get their nickname from!]and repaired the wire[temp with conectors] but now the switch seems to run hot? does anybody have any idea's why this is ,im sure it was ok before please :help: anyway on a brighter note my recaro interior is in :clap: :D so much better than standard seats! Quote Share this post Link to post Share on other sites
Phil K 0 Posted August 5, 2008 New interior looks nice! I have a feeling the headlight switch is constantly illuminated (so you can find it in the dark) so the heat from the lamp inside makes the surface warm - maybe the lamp had failed on your old one! Could be talking rubbish but thats my best guess for ya! Quote Share this post Link to post Share on other sites
bazzabugs1 0 Posted August 5, 2008 Liking it :) very nice motor mate Quote Share this post Link to post Share on other sites
tedman 0 Posted August 5, 2008 yer thanks lads ,think its just me with the headlight switch just dont want another cloud of smoke from the car! :lol: Quote Share this post Link to post Share on other sites
emirc 0 Posted October 17, 2008 My God, what a beautiful coupe VW used to make... What the hell happened?! Quote Share this post Link to post Share on other sites
tedman 0 Posted January 6, 2009 not the update i was hoping for! I was stopped in traffic on the motorway when a nice young lady in a pug 106 went straight into the back of it :mad2: {looks worse in real life plus the bumper is scuffed} looking on the plus side its not a write off and has givern me an excuse for some subtle mods :D going to get the vw badge plated over along with the rear wiper hole,colour code the swg corrado badge and smooth the rear tow eye.also getting some minor corrosion around the filler cap and door sorted. dropped the car off at pf auto's today and can't wait to get it back, then its finally getting the 288's fitted along with mk4 rears. terry Quote Share this post Link to post Share on other sites
__Andy__ 0 Posted January 6, 2009 bit of a pi$$er dude, hope she is paying for all the work. got a huge soft spot for ice grey rado's. look forward to seeing the new mods... Quote Share this post Link to post Share on other sites
tedman 0 Posted January 6, 2009 veedub21 said: bit of a pi$$er dude, hope she is paying for all the work. got a huge soft spot for ice grey rado's. look forward to seeing the new mods... cheers mate yer its going through insurance and im paying some on top to have the mods done. Quote Share this post Link to post Share on other sites
Goldie 2 Posted January 6, 2009 Thats not ideal but what a good opportunity to take advantage of the situation.. Im sure there are many of us that would take a little nudge in the rear to get rid of tow eyes etc.. Quote Share this post Link to post Share on other sites
Toad 0 Posted January 6, 2009 Goldie said: Im sure there are many of us that would take a little nudge in the rear to get rid of tow eyes etc.. :lol: I need to think up a towing eye removal service. Back on topic, and it does look a really nice car. Looking forward to seeing pictures of it when repaired. Quote Share this post Link to post Share on other sites
