junkie 0 Posted April 13, 2008 Where is the safest place to put axle stands on the front of the car to work underneath the car, im always paranoid about where i put them, as i have to remove the downpipe, turbo, manifold and im going to be under there for quite a while i should imagine so i want the safest possible way to do it. Cheers Quote Share this post Link to post Share on other sites
Toad 0 Posted April 13, 2008 I'd drive it onto some sleepers. no chance of it falling off then, or any damage to the chassis from the axle stands... Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted April 13, 2008 block of wood between axel stand and sill,spreads load out and with no damage,but i usualy fit the stands under the front subframe or rear beam. Quote Share this post Link to post Share on other sites
carpoid 0 Posted April 14, 2008 I want to get my car completly off the ground soon, all 4 wheels up fairly high so i can get underneath and do a hub conversion etc. Bearing in mind all i have is the jack in the boot at the mo, what is the best way of actually getting it onto the wooden blocks or axles stands? one wheel at a time ?? Anyone have any pics ?? Quote Share this post Link to post Share on other sites
mariojoshi 1 Posted April 14, 2008 This always seems to a question that no one really knows the answer to. We all use different methods I guess. personally, I've made some wooden blocks the fit in the seat of my axle stands. These have a groove cutout in the top for the sill to sit in. I'm not convinced that this is the best way to keep the front end in the air, but it certainly hasn't squashed the sill yet... ...oh, and I'm not dead due to car squishage...either. Quote Share this post Link to post Share on other sites
boost monkey 0 Posted April 14, 2008 no no no, best place for load-bearing items such as this is current load bearing points, that is, mounting points. Subframe rear chassis mounts are the best, and the \_/ shape of the stands fits in them so well. Here's 2p, spend it wisely. Piccy: winpoints.JPG[/attachment:3pphnj77] Quote Share this post Link to post Share on other sites
boost monkey 0 Posted April 14, 2008 I want to get my car completly off the ground soon, all 4 wheels up fairly high so i can get underneath and do a hub conversion etc. Bearing in mind all i have is the jack in the boot at the mo, what is the best way of actually getting it onto the wooden blocks or axles stands? one wheel at a time ?? Anyone have any pics ?? btw, you should never use 4 axle stands to put a car up on, always 2 stands and 2 ramps / blocks. Not that you would, but just for reference :grin: Quote Share this post Link to post Share on other sites
fla 9 Posted April 15, 2008 Yep those are the points to use. In the stand, use some thick rubber (at least 1cm thick) to prevent or minimise any damage to the underseal. Also use this or a stout piece of timber when using a trolley jack. BTW, can you jack up the rear on the axle? Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted April 15, 2008 btw, you should never use 4 axle stands to put a car up on, always 2 stands and 2 ramps / blocks. Not that you would, but just for reference :grin: Why not? Not that i ever have, i've always used 2 stand and ramps. Quote Share this post Link to post Share on other sites
boost monkey 0 Posted April 15, 2008 It's alright if you're not going to work on a car, but I wouldn't recommend going underneath one on four stands. General concensus is that 4 stands is dodgy: if you start hitting something or giving it any kid of lateral/horizontal force, the car has a high risk of toppling. Putting the wheels under the sills is a good safety measure, but nothing is as good as 2 stands / 2ramps combo. Read this, looks quite useful and easy to do: Make your own ramps Quote Share this post Link to post Share on other sites
boost monkey 0 Posted April 15, 2008 In the stand, use some thick rubber (at least 1cm thick) to prevent or minimise any damage to the underseal. Why? if you're jacking on the subframe mounts then you're jacking up on metal plates so the underseal doesn't come into it, therefore no need to worry about tears/damage. BTW, can you jack up the rear on the axle? Yep, rear axle mount points. they're the HUGE ones. Quote Share this post Link to post Share on other sites
