Mike Edwards
Curious...
The black VR6 is sulking at the local Bosch garage at the moment.
It has:
Fuel in each cylinder (injectors serviced);
Spark in each cylinder (new coilpack, lead and plugs);
Compression in each cylinder (all well within tolerance);
No hint of ignition in cylinder 3 whatsoever.
The garage have asked to borrow my copy of the Bently...
"No hint of ignition in cylinder 3 whatsoever."
Oh it *can*, it just doesn't WANT to.
You know what these VWs are like...
Problem has been traced to the ECU.
It's sequentially injecting fuel into cylinder number 3 at completely the wrong time... :?
Will a ECU reset cure the fault or do you need a replacement ?
It isn't a problem that a reset will fix.
A replacement ECU is one option, but then I'd have to remap it to suit the Shrick etc.
The garage are going to go looking for dodgy connections tomorrow...
Could you not just swap the mapping chip from your old ECU into the new one ?
