vdubbster 0 Posted April 30, 2008 hi, we are currently working on a customers vw corrado, the car a is a minter and we have had to replace the rear panel on it due to being hit from behind. the customer has requested we replace the chassis sticker which is found on the inside of the rear panel. but after speaking to vw we found these stickers are no longer availible has anyone else come across this problem and how did you deal with it? we no there is another vin plate on the car under the bonnet but the customer would like this sticker replaced to keep the car original as possible james Quote Share this post Link to post Share on other sites
Guest Posted April 30, 2008 only thing you can do is scan it and re print it, the stickers themselves are duplicated into the service book on the front cover, if it has one then maybe you could have that scanned and printed onto sticky paper You wouldnt be able to buy one from VW ever as they are unique to the car as they carry the vin, engine, paint and gearbox codes as well as the optional extras/trim code list Quote Share this post Link to post Share on other sites
Walesy 0 Posted April 30, 2008 Hmmm, one of the first things I allways do when buying a rado is check to see if that sticker is there, if it isnt then its a pretty good indication that the cars had a rear end shunt, which is probebly why he would like the sticker replaced :? I'd say its a good thing that they aren't available. Quote Share this post Link to post Share on other sites
Guest Posted April 30, 2008 Well it depends how you look at it, a bent panel is a minor thing, no different to a wing or a bonnet or rear 1/4, i do agree that the reason for replacing the sticker would be to "original" the panel and maybe "diguise" the rear end repair But then if its repaired properly and not recorded damage then i guess theres loads of cars like it about :| Quote Share this post Link to post Share on other sites
stormchaser 0 Posted May 3, 2008 see if these people will make some with the details from your sticker. http://volkswagenstickers.co.uk/ Quote Share this post Link to post Share on other sites
Adz The Rat 0 Posted May 3, 2008 Related post, how do you find out what all the option codes mean?? Quote Share this post Link to post Share on other sites
tonedef 9 Posted May 4, 2008 Related post, how do you find out what all the option codes mean?? You can try http://www.igorweb.org/equidec/ but don't expect 100% accuracy :) Quote Share this post Link to post Share on other sites
MK1Campaign 0 Posted May 4, 2008 My boss had the metal front and the paper rear remade for his MK1 Golf a few weeks back. Its done through VW iirc. Ill find out for you. Quote Share this post Link to post Share on other sites
Adz The Rat 0 Posted May 4, 2008 Related post, how do you find out what all the option codes mean?? You can try http://www.igorweb.org/equidec/ but don't expect 100% accuracy :) Will give that a try 2moro, thank you!!! Quote Share this post Link to post Share on other sites
vdubbster 0 Posted May 5, 2008 hi, thanks for all your replys...mk1campaign...if ya could find out about VW iirc then i would be very gr8full still havent got it sorted yet.. james. Quote Share this post Link to post Share on other sites
