dirtytorque 0 Posted May 1, 2008 any guidance would be greatly received. :salute: Quote Share this post Link to post Share on other sites
flusted 0 Posted May 2, 2008 black/red coil wire? Quote Share this post Link to post Share on other sites
dirtytorque 0 Posted May 2, 2008 yeah,i've read that in a couple of places but all my install has is a green ignition wire and the black 12 volt wire. Dunno if any other g60 owners can confirm?!?? :help: Quote Share this post Link to post Share on other sites
Riley 0 Posted May 2, 2008 If it helps mate, i know that the rev counter feed enters the fuse box on the top via a black spade connector. There are 2 or 3 next to each other on the top right of the fuse box, and its the one to the left of the 2/3. Neil. Quote Share this post Link to post Share on other sites
flusted 0 Posted May 2, 2008 well it pulls it from coil -. you could always just add a wire to coil - Quote Share this post Link to post Share on other sites
dirtytorque 0 Posted May 2, 2008 flusted said: well it pulls it from coil -. you could always just add a wire to coil - thats what i thought but the original cooil wire is connected to the egative terminal but still no rpm. In the bentley it just shows the green wire from the neg going to the ecu. Quote Share this post Link to post Share on other sites
CTWG60 0 Posted May 2, 2008 I always thought it was from the ecu although a lot of older cars do take it from the coil. Quote Share this post Link to post Share on other sites
