Leonard 0 Posted August 27, 2008 I am a bit worried about just pulling it off in case anything snaps. Or if it bends so much that it no longer fits flush on top of the door/against the window? Any tips would be appreciated. Also I take it the rear window seal is a professional only job and once out cannot be re-used???? Thanks Matt Quote Share this post Link to post Share on other sites
dinkus 10 Posted August 27, 2008 I believe the front seals do just pull off, but be careful as they're hideously expensive new... The rear 1/4 windows are bonded in as a single piece window and seal. The only way to get them out is to cut them carefully out from the inside. If you do a neat job, you can clean up the glue stuff and re-use them. Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted August 27, 2008 The fronts are glued to the door and have a metal insert which can bend, £150 a side or there abouts if you bugger them up!! :shock: Quote Share this post Link to post Share on other sites
Leonard 0 Posted August 28, 2008 The fronts are glued to the door and have a metal insert which can bend, £150 a side or there abouts if you bugger them up!! :shock: Hmmm thanks guy's so is there a recomended way of taking them off? Should i slide a knife under them first? Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted August 28, 2008 All i know is that they're bonded to the door on the inside edge, sorry. Quote Share this post Link to post Share on other sites
Leonard 0 Posted August 28, 2008 All i know is that they're bonded to the door on the inside edge, sorry. Thats ok that is pretty helpful :D Thanks Matt Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted August 28, 2008 Oh and there is a screw at the bottom rear and a clip at the front edge, the screw of which holds on the black triangular trim by the mirror. Quote Share this post Link to post Share on other sites
Leonard 0 Posted August 28, 2008 Oh and there is a screw at the bottom rear and a clip at the front edge, the screw of which holds on the black triangular trim by the mirror. I knew you knew more that you werent telling LOL Cheers Matt Quote Share this post Link to post Share on other sites
KIPVW 0 Posted August 28, 2008 Are you talking of the seal that goes over the top of the door frame or the one that runs along the base of the glass on the door? Sorry for sounding thick! but if it is this seal you are after i thought they were only aroung £50 each. from GPC and the like. Quote Share this post Link to post Share on other sites
Leonard 0 Posted August 28, 2008 Are you talking of the seal that goes over the top of the door frame or the one that runs along the base of the glass on the door? Sorry for sounding thick! but if it is this seal you are after i thought they were only aroung £50 each. from GPC and the like. Hi m8 Well my car is in for respray (as you know) so it is the outer seal along the door. My painter was a bit worried about just 'pulling it off' . I can live with the rear window being masked but I defo want the door paint going under the seal... Just don't want to feck it up upon removal :( If they are 'only' £50 then that is slightly less of a worry though. Cheers Matt Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted August 28, 2008 The straight horizontal ones come off okay but they too have a metal insert and can be bent if you're not a bit careful. I've had mine off several times >snigger! Quote Share this post Link to post Share on other sites
Leonard 0 Posted August 28, 2008 The straight horizontal ones come off okay but they too have a metal insert and can be bent if you're not a bit careful. I've had mine off several times >snigger! So are these glued on? Quote Share this post Link to post Share on other sites
KIPVW 0 Posted August 29, 2008 No, Well they shouldn't be anyway they press down onto the door and hold in place because they have metal inside the rubber to grip the fram. As said be extreemly carefull on removal as they bend easy, i replaced both mine when i had some paint done as new ones look far better too but it adds more cost to the whole job :? Good luck mate. Quote Share this post Link to post Share on other sites
Leonard 0 Posted September 1, 2008 Rang a few people up today about taking the rear windows out. Because of the age of the car though nobody was prepared to do it. Did wonder if it was just an excuse as the job was tricky, low cost and with quite a high fook up factor? So just going to have to have them masked and hope for the best on the paint job! Quote Share this post Link to post Share on other sites
carpoid 0 Posted September 1, 2008 Thats a shame nobody wanted to do it, mine is in for a respray at the moment and the painter knew someone who removes glass, he took out all the interior trim, and cut the sealant from the inside with a blade held flat against the screen, with soapy water. Coolrado told me how he done his, and i printed it off for him. The seals along the bottom of the driver/passenger windows are called window slot seals 535837473A01C and 535837474A01C for left and right, i paid 33 pounds each from GPC. Matt Quote Share this post Link to post Share on other sites
Leonard 0 Posted September 1, 2008 Thats a shame nobody wanted to do it, mine is in for a respray at the moment and the painter knew someone who removes glass, he took out all the interior trim, and cut the sealant from the inside with a blade held flat against the screen, with soapy water. Coolrado told me how he done his, and i printed it off for him. The seals along the bottom of the driver/passenger windows are called window slot seals 535837473A01C and 535837474A01C for left and right, i paid 33 pounds each from GPC. Matt Yeah it is a shame as I do like things to be 100%. If I really dont like it when I get it back I will just have to get it done at a later date :( Thanks for the part no's £33 from GPC sounds good, so think I will just get some new ones :) Quote Share this post Link to post Share on other sites
carpoid 0 Posted September 1, 2008 Not a problem mate, had a quick look at your VR just now, looks interesting, very nice.... Did you have your rear screen taken out ? GPC told me the seal for those was obsolete, but i got one from VW, same as the windscreen, the 'seal' on the outside is just trim, can be removed without taking the window out, and are available from VW too, Rear Screen VW-535853355A01C ($166.75 AUD) Front Screen VW-535845127A ($86.15 AUD) Hope all goes well !! Quote Share this post Link to post Share on other sites
Leonard 0 Posted September 1, 2008 Thanks mate. I have defo been kick started into sorting the car out after seeing how nice it looked originally :D Just having it sprayed from windows down, so only the rear 3/4 window is a problem area. Just as well looking at all the prices for seals! Fingers crossed Matt Quote Share this post Link to post Share on other sites
