20vturbo 0 Posted March 22, 2012 have the car booked in for a nct on the 12th of may so the big push is on now to get it finished started with a standard center console fitted my 3 stack gauges where the ashtray was getting all the wiring sorted and making a start on the interior fuse box in place, tried to get the wires as tidy as possible but corrado wiring isnt known for it neatness both front seats in and the interior pretty much back together Quote Share this post Link to post Share on other sites
WigsVR6 0 Posted March 23, 2012 Wow I thought this build thread had died ages ago. Nice to see it back on track. Keep up the good work this is one of my favorite build threads. Alan Quote Share this post Link to post Share on other sites
20vturbo 0 Posted March 23, 2012 WigsVR6 said: Wow I thought this build thread had died ages ago. Nice to see it back on track. Keep up the good work this is one of my favorite build threads. Alan between being in america and being in hospital at the end of last year i wasnt able to work on it for a long time but its booked in for a nct (irish version of the mot) on the 12th of may so it has to be all finished for that and then im driving it to a car show on the 27th of may, really really cant wait to properly drive it. Quote Share this post Link to post Share on other sites
dickie 0 Posted March 23, 2012 hi, what did you do about frames for the front seats? made or bought? Quote Share this post Link to post Share on other sites
20vturbo 0 Posted March 24, 2012 dickie said: hi, what did you do about frames for the front seats? made or bought? i used the evo runners which have a better ball bearing setup and made brackets to mount them. Quote Share this post Link to post Share on other sites
20vturbo 0 Posted April 1, 2012 the underside all cleaned up front arch liners fitted rear arches cleaned Quote Share this post Link to post Share on other sites
20vturbo 0 Posted April 19, 2012 new track rod ends anti roll bar striped back to the metal primed and painted new powerflexed drop links anti roll bar fitted air filter fitted infront of the drivers wheel made a new bracket for the washer bottle washer bottle fitted in the car, kept it lower than standard to clear the bonnet lifter washer jets fitted, wired and piped up vibratechnics competion engine mount new facet fan switch 2 new bosch horns new front top mounts proper pressed in INA bearings instead of the crap plastic ones 2 part polyurethane filling the gap at the bottom of the top mounts with polyurethane to stop the problem of the rubber breaking down and the top mount coming up threw the hole in the suspension turret. should make the front end nice and sharp Quote Share this post Link to post Share on other sites
job705 10 Posted April 20, 2012 Just all top clas fella top clas rebuilt Quote Share this post Link to post Share on other sites
20vturbo 0 Posted May 7, 2012 the first few pieces of carbon fiber ive started doing, wrapped the handbrake handle and then a coat of lacquer to finish it the car all loaded up and ready for tracking in fahys garage and a day with joe on the dyno. there was a few issues with the ecu during the first mapping session so it could only be mapped at 1.0 BAR. the car made 260BHP at 1.0BAR so still alot of power left to get, should be back in the next 2 weeks for the final map. coilovers wound up to get the car on the dyno and for the nct when it was on the dyno it pulled a stud out of the manifold so i changed all the studs in the manifold from m8 to m10 for more strenght. all the holes drilled and tapped drilled the holes in the turbo for the bigger studs this is what happened to the gasket when the stud pulled out Quote Share this post Link to post Share on other sites
20vturbo 0 Posted June 22, 2012 so after over 4 years of work, i started when i was 15 and now im nearly 20 years old, the car is finally on the road. it flew through the nct ( irish version of the mot) and theres tax on the windscreen. i have been driving it for nearly the last month and i absolutly love it. it was 100% worth all the work and effort. a pic from its first week on the road one of the last big jobs on the car that ive been waiting to do for a long time painting the wheels, started out like this. sanded and ready for primer a coat of primer base coat a coat of lacquer and back on the car, then i gave it a quick wash a few pics i robbed off the internet from the limerick vw show still a load of jobs to do and always something to improve so i wont actually be ever able to say its finished. Quote Share this post Link to post Share on other sites
joby 0 Posted June 22, 2012 spot on you should be very proud of yourself, what wheels are those and are you using spacers Quote Share this post Link to post Share on other sites
20vturbo 0 Posted June 22, 2012 joby said: spot on you should be very proud of yourself, what wheels are those and are you using spacers thanks, the wheels are 17" bbs rc's and im using 15mm spacers all round Quote Share this post Link to post Share on other sites
BILLCOR 1 Posted June 22, 2012 Was hard to believe you were only 15 when you started this, top work young sir and awesome comitment :salute::salute: PS. Prefer the RC's with the centre caps on :thumbleft: Quote Share this post Link to post Share on other sites
20vturbo 0 Posted June 22, 2012 BILLCOR said: Was hard to believe you were only 15 when you started this, top work young sir and awesome comitment :salute::salute: PS. Prefer the RC's with the centre caps on :thumbleft: if someone told me when i started it would take nearly 5 years i would have laughed at them, so happy its finally done, i have a set of polished center caps for the rc's but i dont want to paint them so im waiting until i get another set. Quote Share this post Link to post Share on other sites
captainredeye 0 Posted June 22, 2012 Not even 20 and you own that, jealous as hell that is one lovely build. Quote Share this post Link to post Share on other sites
Portent 0 Posted June 22, 2012 Very well done. You can justifiably be very proud of yourself :notworthy: Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted June 22, 2012 Id forgotten about this lil gem. I guess you are pleased with it mate? Are you heading over here to any shows? Im sure a few folk from this forum would love to see it.... :D PS fancy doing another set of fancy top mounts?? ;) Quote Share this post Link to post Share on other sites
VR6 0 Posted June 22, 2012 Brilliant thread and an amazing project! Quote Share this post Link to post Share on other sites
BILLCOR 1 Posted June 22, 2012 20vturbo said: if someone told me when i started it would take nearly 5 years i would have laughed at them, so happy its finally done, i have a set of polished center caps for the rc's but i dont want to paint them so im waiting until i get another set. I may have some discs and centres, will have a look Quote Share this post Link to post Share on other sites
20vturbo 0 Posted June 23, 2012 VAG-hag said: Id forgotten about this lil gem. I guess you are pleased with it mate? Are you heading over here to any shows? Im sure a few folk from this forum would love to see it.... :D PS fancy doing another set of fancy top mounts?? ;) im very pleased with it, i just have to do all the fine tuning now like setting the stiffness of the coilovers. i was going to go to inters but i couldnt make it so if anyone can recommend and good show worth going to maybe with a drag strip id have no problem doing another set of top mounts, the only thing is they raise the front of the car about 20mm but its fine if you have coilovers because you can just wind them down. ---------- Post added at 11:25 AM ---------- Previous post was at 11:25 AM ---------- BILLCOR said: I may have some discs and centres, will have a look ya thanks that would be great Quote Share this post Link to post Share on other sites
VW_OwneR_85 2 Posted June 23, 2012 awesome work man, gave me motivation when i was doing my bodywork, still cant belive you were only 16 at the time, Quote Share this post Link to post Share on other sites
db82 0 Posted July 5, 2012 What a build, makes me want to get mine finished asap, just wondering though what throttle cable did you use? and did you have a issues with the throttle body fouling on the bonnet? Dave Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted July 5, 2012 20vturbo said: im very pleased with it, i just have to do all the fine tuning now like setting the stiffness of the coilovers. i was going to go to inters but i couldnt make it so if anyone can recommend and good show worth going to maybe with a drag strip id have no problem doing another set of top mounts, the only thing is they raise the front of the car about 20mm but its fine if you have coilovers because you can just wind them down. PM'd Quote Share this post Link to post Share on other sites
tentonhammer 10 Posted July 6, 2012 Awesome build. Inspiring even. Oh to have a garage.... ! Quote Share this post Link to post Share on other sites
