le hubs 0 Posted March 24, 2009 I was after abit of info please. My 16v Corrado is running terribly a the minute and im pretty sure the engine is on its way out. I was just wondering if a G60 engine will fit? Thank you Quote Share this post Link to post Share on other sites
dirtytorque 0 Posted March 24, 2009 it will physically fit ,yes. Quote Share this post Link to post Share on other sites
Yandards 0 Posted March 24, 2009 But you will need to do/get the following: complete g60 wiring loom from fusebox to engine bay remove the brake servo to get to the wiring loom entry point into the interior (pain in the arse of a job) g60 driveshafts g60 brakes engine and all ancils, charger etc G60 PAS pump, brackets and plumbing Intercooler and pipework G60 CAT/CAT bypass along with a different downpipe (standard valver one is different) G60 ECU G60 dash clocks, the vacuum sensor on the back for the MFA is of a higher pressure and is matched to the sensor on the clocks printed circuit board. G60 radiator and all the cooling hoses You can still run a 16v fuel delivery system (it's better suited even as it is a higher pressure pump) but you will need to adapt the existing k-jet fuel lines. Apart from that its a doddle :) Quote Share this post Link to post Share on other sites
oldskoolkool 0 Posted March 24, 2009 But you will need to do/get the following: complete g60 wiring loom from fusebox to engine bay remove the brake servo to get to the wiring loom entry point into the interior (pain in the arse of a job) g60 driveshafts g60 brakes engine and all ancils, charger etc G60 PAS pump, brackets and plumbing Intercooler and pipework G60 CAT/CAT bypass along with a different downpipe (standard valver one is different) G60 ECU G60 dash clocks, the vacuum sensor on the back for the MFA is of a higher pressure and is matched to the sensor on the clocks printed circuit board. G60 radiator and all the cooling hoses You can still run a 16v fuel delivery system (it's better suited even as it is a higher pressure pump) but you will need to adapt the existing k-jet fuel lines. Apart from that its a doddle :) hahaha doddle ledgend! Quote Share this post Link to post Share on other sites
le hubs 0 Posted March 24, 2009 ahhhh not as simple as i had hoped!! Is there another engine that would be easier? Quote Share this post Link to post Share on other sites
oldskoolkool 0 Posted March 24, 2009 the same one but modded pehaps :shrug: Quote Share this post Link to post Share on other sites
dirtytorque 0 Posted March 24, 2009 ok i'm out of my comfort zone here so i may be wrong but i think the abf engine can be run on your existing electronics and has similar power output to a standard g60. Hopefully someone with more knowledge will be along to confirm or deny. failing that just by a g60. :) Quote Share this post Link to post Share on other sites
Rustynuts 0 Posted March 24, 2009 ABF will slot in with no problems, all you need is the block and head, all other ancilliaries will come off the old 1.8 16v engine. Same applies for the 2.0l 9a out of a later Corrado, though it's worth swapping the KR cams over to this engine to get the best out of it Quote Share this post Link to post Share on other sites
