dazzyvr6
vr6 spark plugs
  BANANA MAN said:
The plugs for the VR6 are NGK BKR5EKU or BKR5EKUP's hope this helps
What plugs should the VR6 be running ? - am using Bosch at mo provided by G & S but have always used NGK's in past....... Any difference?
To be honest scott there is going to be minimal difference between the NGK's and the bosch plugs. NGK's are the original equipment plugs used on the VR's out of the factory thats all, the BKR5EKUP's are platinum plugs which are recomended for the VR's as they have a better heat tolerance and will probably give a slightly better spark which means a little more power but they are quite expensive I think without looking I wouldn't be able to tell you the prices but the NGK platinums are likely to cost at least double what you pay for normal BKR5EKU's.
