dazzyvr6 0 Posted November 25, 2002 anyone got the spark plug numbers handy,i know its ngk xxxxx Quote Share this post Link to post Share on other sites
Banana Man 0 Posted December 4, 2002 The plugs for the VR6 are NGK BKR5EKU or BKR5EKUP's hope this helps Quote Share this post Link to post Share on other sites
Scott 0 Posted February 11, 2003 BANANA MAN said: The plugs for the VR6 are NGK BKR5EKU or BKR5EKUP's hope this helps What plugs should the VR6 be running ? - am using Bosch at mo provided by G & S but have always used NGK's in past....... Any difference? Quote Share this post Link to post Share on other sites
Banana Man 0 Posted February 11, 2003 To be honest scott there is going to be minimal difference between the NGK's and the bosch plugs. NGK's are the original equipment plugs used on the VR's out of the factory thats all, the BKR5EKUP's are platinum plugs which are recomended for the VR's as they have a better heat tolerance and will probably give a slightly better spark which means a little more power but they are quite expensive I think without looking I wouldn't be able to tell you the prices but the NGK platinums are likely to cost at least double what you pay for normal BKR5EKU's. Quote Share this post Link to post Share on other sites
