eugopnosaj 0 Posted December 30, 2009 I haven't had a chance to look at mine, need to get it up but just haven't had the time, its stopped working completely now, no more random temperatures so im guessing it'll need replacing. Does anyone know the part number so i can at least investigate prices Thanks Quote Share this post Link to post Share on other sites
Kempy 0 Posted January 2, 2010 thought id look at this today, mine seems to be on the other side to the pic? or is it cause its a pics :cuckoo: mine reads 50oC but I fiddled with the covers for the toe eyes today and it read 47oC. is the sensor inside the bumper? Quote Share this post Link to post Share on other sites
Matt DDK 0 Posted January 2, 2010 Until Reading this thread I didn't realise Corrados were fitted with temp sender. It's been bugging me for a while as every other v dub has them, my MFA only shows oil temp and the usual mpg and times. When I removed the bumper recently I didn't have a sensor, can anyone confirm the wire colours and where it meets the loom. Thanks Matt Quote Share this post Link to post Share on other sites
Toad 0 Posted January 3, 2010 2 pin connector, drops down through a hole under the airbox. Quote Share this post Link to post Share on other sites
panderoo 0 Posted January 3, 2010 i could do with knowing the wire colours for this sensor as i think i may have chopped then out the loom when i was fitting the 20v... :epicfail: if someone knows the wire colours i could find the plug and wires out the old loom hopefully and re-attach them.. Quote Share this post Link to post Share on other sites
dragon green 6 Posted January 3, 2010 The two wires are red and white stripe,and brown and white stipe, or thats what they are on mine two pics show position of sensor,one with the vented brake, the other standard fitting On the drivers side Quote Share this post Link to post Share on other sites
Matt DDK 0 Posted January 3, 2010 Thanks very much for the pics and wire details, time to put my hat a gloves on and get outside :) Regards Matt Quote Share this post Link to post Share on other sites
PaulMoVR6 0 Posted January 4, 2010 Is it best to remove the grill piece to get at the sensor? Cheers Quote Share this post Link to post Share on other sites
PaulMoVR6 0 Posted January 23, 2010 Got the sensor on this morning i now have a reading comeing up in the dash but its showing -40c constantly Take it my new sensor is buggered? Paul Quote Share this post Link to post Share on other sites
PaulMoVR6 0 Posted February 11, 2010 Right i have now fitted 2 sensors and iam constantly getting 50c showing with either sensor Any ideas? wireing issue? cheers paul Quote Share this post Link to post Share on other sites
dragon green 6 Posted February 11, 2010 when i lost my sensor,i bought a new one,like yours it read 50c ! managed to pick two up from the breakers :D both still read 50c :( I too posted on here,the advice i was given,was most likely a break or short in the wire,trace the wires back until you find anything ! Never got round to it, but did notice my sensor worked, sort of !! 40c on my sensor is 0c, Mine only works in the winter, as it only goes upto 10c ! I have a bentley manual but i cant find anything about re-calibration of the sensor ! Sorry i cant help you anymore, Good luck and keep us informed Quote Share this post Link to post Share on other sites
PaulMoVR6 0 Posted February 11, 2010 ok i see, mine dosn't move atoll from 50c thats two that i have tryed, when i went to fit the sensor the first time though the connector had been cut off and it was just the 2 wires showing i think a previous owner obviously had a problem with it and just decided to do away with it altogether, ill have a look at the wires though cheers Quote Share this post Link to post Share on other sites
