V-Dubstar 0 Posted January 28, 2010 Im gonna detail my headlights (painting the reflectors inside), and was wondering what people have used and if they've encountered any problems in doing so etc? Was thinking of some sort of high temp paint? TIA :grin: Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted January 28, 2010 I just used some satin black hammerite from halfords and a angled brush. Was easy and didnt take long at all. Quote Share this post Link to post Share on other sites
Guest Posted January 28, 2010 ^^^agreed^^^ dont think you hav to worry to much about heat and normal paint will take the heat that your lights give off Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted January 28, 2010 ^^^agreed^^^ dont think you hav to worry to much about heat and normal paint will take the heat that your lights give off The part of the reflectors you paint is sat in front of the bulb anyway so heat def shouldnt be a problem. Quote Share this post Link to post Share on other sites
Kempy 0 Posted January 28, 2010 thought yours were done already :cuckoo: Quote Share this post Link to post Share on other sites
V-Dubstar 0 Posted January 29, 2010 thought yours were done already :cuckoo: Nope, definately not :lol: Quote Share this post Link to post Share on other sites
C488ADO 0 Posted January 29, 2010 black permenant marker worked for me... Quote Share this post Link to post Share on other sites
daves16v 1 Posted January 30, 2010 I had some Black garage door paint lying around so used that, it's similar stuff to hammarite. Worked a treat. Quote Share this post Link to post Share on other sites
Sam.l 0 Posted May 4, 2010 Sorry for the hijack of this thread, but was thinkin about doin the same thing to my headlights. I have also seen people detail the inner around the full beam in yellow, has anyone done this and what did they use to do it? Thanks. Quote Share this post Link to post Share on other sites
swiftkid 1 Posted May 4, 2010 G60greeny did it to his, something i've been wondering as well. Quote Share this post Link to post Share on other sites
Sam.l 0 Posted May 4, 2010 Anyone got any pic's of this mod or any pointers on what best way to go about it? Quote Share this post Link to post Share on other sites
daves16v 1 Posted May 4, 2010 Anyone got any pic's of this mod or any pointers on what best way to go about it? Haven't got any pics but just take your time when painting - be fussy 8) The paint I used was Hammerite smooth garage door paint, only because I had it lying around. Quote Share this post Link to post Share on other sites
V-Dubstar 0 Posted May 4, 2010 Anyone got any pic's of this mod or any pointers on what best way to go about it? Haven't got any pics but just take your time when painting - be fussy 8) The paint I used was Hammerite smooth garage door paint, only because I had it lying around. I think Sam is more concerned with going about getting the circular bit yellow? Could be wrong tho... Agree with u Dave, make sure u get in everywhere but be SUPER careful :D Quote Share this post Link to post Share on other sites
Sam.l 0 Posted May 4, 2010 Ideally i wanna do both, paint the faces of the inners black and the inners of the full beam yellow. Just wonderin' what paint to use for the yellow? mmmm. Am guessin you cant mask off the lights 'cos you'd wreck the reflectors, so a carefull and patient hand is needed i guess? Quote Share this post Link to post Share on other sites
V-Dubstar 0 Posted May 4, 2010 Ideally i wanna do both, paint the faces of the inners black and the inners of the full beam yellow. Just wonderin' what paint to use for the yellow? mmmm. Am guessin you cant mask off the lights 'cos you'd wreck the reflectors, so a carefull and patient hand is needed i guess? Yup, and tbh, unless u've got a major case of the shakes or somethin', u'll be fine! Take ur time, cover everywhere, move the headlight around in different angles in the light to check u haven't missed anywhere. As for the yellow, not sure mate - was tempted to do it myself but bailed!! Quote Share this post Link to post Share on other sites
Sam.l 0 Posted June 21, 2010 So, finally gonna get round to detailing the headlights and gonna pop down to halfords or somewhere to get some hammerite. Also thinkin....C488ADO, you said you used a permanent marker to do yours, did you find it left a mattalic kind of finish? Sometimes those permanent markers leave a purply colour. Is it noticable or did it not leave that colour? :) Thanks. Quote Share this post Link to post Share on other sites
V-Dubstar 0 Posted June 21, 2010 I used a permanent marker too mate, colour was fine. I bought a new Edding marker for the job. If I did it again tho Id use paint because there were a couple of areas hard to get the marker right in. Quote Share this post Link to post Share on other sites
Sam.l 0 Posted June 21, 2010 I suppose i could give it a go with the marker and i could always paint over it if it doesnt work out too well? Only thinkin 'cos i got a marker now to give it a go with! :) Quote Share this post Link to post Share on other sites
V-Dubstar 0 Posted June 21, 2010 Yeh man, I managed like. But there's some deep recesses along the vertical point in which ur effectively 'seperating', that were hard to get into! Good luck dude! Good opportunity to clean all the green gunk from between the glass/plastic etc! Quote Share this post Link to post Share on other sites
Sam.l 0 Posted June 26, 2010 Well finally got round to the headlights yesterday, and the marker worked a treat. I ended up leaving the recess inbetween the main beam and full beam 'cos like you said V-Dubstar, it was a bit of a nightmare to get to! But they look kickass now and I gave 'em a good clean in the process. May split them again as i wouldnt mind paintin the full beam inners yellow. mmmm :) Quote Share this post Link to post Share on other sites
