MonkeyVR6
Uprated bulbs: Phillps Vs Osram, opinions required.
Today I fitted some standard LHD headlights that I managed to aquire.
All I need to do is uprate the awful standard headlights so I can see where I'm going at night :wink:
Has anyone used either of these in H4? I have used the Phillips bulbs in H7, but they were also in my InPro style headlights that I'm now selling.
I'm also considering buying an uprated headlight loom and I assume this will also help.
OSRAM NIGHT BREAKER
http://www.powerbulbs.com/product_detail.asp?prod=111
PHILLIPS X-TREME POWER
http://www.powerbulbs.com/product_detail.asp?prod=43
Cheers.
Check out some PIAA bulbs, bit pricey but will out shine both the Osram & Phillips bulds
Never heard of PIAA. Whats the score with them?! Guess I'm going to have to do a bit of geekin' on Google!
Extreme +80% H4s and Nightbreaker +90% H3s, award winners in Autotest at the time.
Very pleased, have an old upgraded loom and recently fitted Lamin-X in the Optic Blue flavour which really whitens the light output further 8) 8) 8)
I fitted the Phillips X-Tremes and they are very, very good. Its a bright white piercing light - would definitely recommend. After fitting them I had to adjust my lights downwards as I was getting flashed by oncomming traffic.
My main beams now seem yellow in colour compared.
Before I buy the bulbs (from powerbulbs btw), I just want to make sure that I'm buying the right shiz.
2 x packs of H4 Phillips X-Treme = 4 x bulbs in total. So both the main beam and dipped beam(sidelights) bulbs are H4?
Cheers :?
No you need H3's and H4's - H4 are the main bulb and H3 are the inner ones (same as the fogs use)
I'm using X-treme's for my H4's and they are the best bulbs i've tried yet!
apparently the best ones we have had in a while are the Ring Xenon Max which are now a 100% brighter bukb! havent tried em yet like. i have the phillips xtreme lol
The best bulbs I've used to date are the 100W Rally bulbs from Phillips, but with 4 of them on (main beams) they pull ~30 amps, which is quite noticable at low rpms from the strain on the Alternator, especially if it's the weedy 70amp one. An uprated loom is also a must.
There is also the small matter of them not being approved for road use either.
They are a LOT brighter than all these NightBreakers and things though.
I used the osram silverstars which where significantly better than the originals, nice white light instead of yellow.
I then switched to the nightbreakers which again where significantly "whiter" next to the silverstars....... i do however find the beam is a bit narrow, as in it doesn't light the verges like some others but they're definitely bright!
