Supercharged 2 Posted April 8, 2010 This is what you need for releasing the terminals from OE plugs - very useful tool to have for loom type stuff along with some Scapa cloth tape. Got mine locally from Bennetts for £5.70 + vat http://www.bennetts.com/electrical-sold ... 683706.php Slightly cheaper from here online - £4.80 +vat http://www.toolsheduk.com/Q/444/2/4/Terminal-Tool.html Quote Share this post Link to post Share on other sites
davidwort 0 Posted April 8, 2010 beats poking about with watchmakers screwdrivers :) Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 8, 2010 beats poking about with watchmakers screwdrivers :) Indeed, I'm not usually a fan of cheap tools (and Laser make some real rubbish) but this seems to do the job well and the VW version costs nearly £30 Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted April 8, 2010 Looks good- how do you use it then? Quote Share this post Link to post Share on other sites
Yandards 0 Posted April 8, 2010 Looks good- how do you use it then? You poke them in the front of the plug and push the cable loom into the plug from the back, this should unlock the little tabs that hold the wiring into the plug and then you can pull the loom complete with crimp from the plug housing. They can be a right fidely pain to work with but the ability to fit and remove wiring from plugs to re-wrap looms etc makes it worthwhile. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 8, 2010 Basically the VW terninals have 2 locking tabs that clip into the plug, that tool simply pushes in and releases them properly so the plug / wire can be re-used. Quote Share this post Link to post Share on other sites
The_Dude 0 Posted April 8, 2010 Awesome! The rear speakers for my car have been cut right at the plug and I had not been able to work out how to get them out for repair. I knew there must be a tool somewhere, nice one! :clap: Quote Share this post Link to post Share on other sites
John-M 0 Posted April 8, 2010 Is it 'one size fits all' ?? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 8, 2010 Is it 'one size fits all' ?? I've only tested a couple so far but seems to work - got it from Bennetts on Foxhall Road by the way John - they had to order it but came in next day.. Quote Share this post Link to post Share on other sites
John-M 0 Posted April 8, 2010 Thanks - I was planning a trip there, so I'll call them first :) Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted April 8, 2010 Female terminals and wire seals to go with the tool - http://www.autoelectricsupplies.co.uk/product/680 So much neater than cutting and shutting existing wires. Simply start over with new terminals etc :D Quote Share this post Link to post Share on other sites
Yandards 0 Posted April 9, 2010 Female terminals and wire seals to go with the tool - http://www.autoelectricsupplies.co.uk/product/680 So much neater than cutting and shutting existing wires. Simply start over with new terminals etc :D Or if you have access to ETKA then there is a specific electronics catalgoue that last every plug and crimp VW have every made along with all the boots, clips and brackets. If you find the part number on your existing plug and then feed that into the electronics catalogue there is a page where it shows male/female plugs and if you double click the plug and then click the box that looks like a screen in the additional info area it shows you all the crimps that fit in that plug. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 9, 2010 Yep, all plugs, terminals and repair wires available from VAG. Just tried to tool on a Headlight switch loom and an electric Window and Mirror loom and it works on every plug! You simply slot in the plug side and pull the wire out the other... Fusebox plugs are interesting though, they seem to have an extra lock that slides across so you need to remove these bits first. Quote Share this post Link to post Share on other sites
VRTrickster 0 Posted October 27, 2010 Would this tool be any good for ecu terminals? They are very small! Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted October 27, 2010 I use these tools, which cover quite a few different pin sizes and plug types. I haven't tried them on an ECU plug yet, so I can't guarantee they'll work on that. http://www.vehicle-wiring-products.eu/V ... gterms.php Quote Share this post Link to post Share on other sites
VRTrickster 0 Posted October 27, 2010 Yeah I've got them myself kev. There not any good for the ecu, they need to be tiny. I'm still having problems with the lambda signal. I'm on Bosch sensor number 3 now, lol! I'm now liaising with Vince at the moment. He has suggested cutting the signal wires and running some test cables as the ecu terminals are a pain to get out even with the tool he uses! Eventually if it cures the problem I would like to run a separate loom to the ecu for the signal wires and use proper terminals. I was looking at this set. Quote Share this post Link to post Share on other sites
