tandino
Diavia Air Con Owners, please look!
Cheers for that. I will study it when sober. Thank you
Sent from my SM-G900F using Tapatalk
Cheers Hasan makes it all a bit clearer now.
It also confirms that there are 2 different relays in the system.
Can anyone tell me which wires they have coming from the pressure switch(Trinary switch)into the loom?
As mine has 2 blues and 2 black/greens and i have no idea which ones they match up to??
I'll have a look this afternoon
[ATTACH]83829[/ATTACH]is this picture any help. The front is still off my car so I can check most things
The cables at the plug are red/black and orange.
And dark green and green/yellow
Green to green.
Green yellow to my blue
Orange to black
Red/black to white
Old thread, but I thought adding my coolant sensor question may help others if I get an explanation.
So, I have just changed the coolant thermostat regulator housing on my late VR.
2 pin black sensor
2 pin blue sensor
4 pin yellow sensor.701-919-369 B. (36-94) Here is my query.....
The Wiki guide mentions 701-919-369D Black(29-18 ) and this is what TPS supplied to me as Etka says I should have the D Version.
As I have the diavia air con fitted, is this why I have the B version fitted?
It definitely has different numbers on the side and I don't want to fit the wrong one.
It all worked fine, I was just replacing all parts to ensure longterm reliability.
All help greatly appreciated
That yellow one has probably been superseded. You should have a brown 4 pin plug as well if you have air con, I have one of these in a box bought in error from the dealer. Pretty sure there should be 4 sensors in your thermostat housing
I've been to TPS today who said it has been superseded to the D. It just seems strange that doing an Ebay search does bring up aftermarket B parts. And that is the only 4 pin sensor fitted, definitely only 3 sensors in there with no space for another ! and no issues with my fans working...
Haven't got a clue what make my A/C system is and not currently with the car, but I'm in the middle of having the dash out, obviously changing the heater matrix, is there anything else that I need to buy that's connected to the A/C that needs replacing?
I only have two sensors in mine, think i read the guide wrong and got rid of the 3rd when i removed aircon. Hasn't caused any issues.
Not really much else in the dash to change really
Not really much else in the dash to change really[/quote
I just remember half my passenger lower dash is modified for the A/C so was guessing that there might be some associated equipment to change out
The fan and heater box is different, but not really much to change, apart from the fan. But don't think thats a dash out job.
cheers Jim
