CazzaVR
OEM VW Parts Price Enquiries
It’s great the community is still strong,keeping the old corrado’s going!! It’s usually the lack of parts that kill off classics.
On that note is there any hope of reproducing the outer weather seals for the corrado in particular the passenger side?
Obsolete worldwide apparently.
Part of my headlight wiring loom was burnt away/warn, partly caused by the original weak headlight switch, due to the poor inner contacts, & the bulb shining hot making parts of the inner plastic brittle as well.
I bought this loom back in 2005 or early 2006 when it was still available from VW main dealer, for roughly £50.00
But it's been obsolete for awhile now, well I've just seen it's been reproduced by VW Classic Parts.
Also remember to speak to VW Heritage as they might do you a deal on price ?
VW Classic Parts.
Headlight wiring loom
OEM part number:
00-535971055
€78.96 = £70.41
All Corrados 1988 to 1995
Or VW Heritage
535971055
£59.71
VW Classic Parts
OEM part n.o
535971055B
€129.00 = £114.80
Or VW Heritage
535971055B
£97.56
One of the above part numbers is RHD and one is for LHD possibly, but you'll have to speak to VW Heritage, as I'm not 100% sure.
Also speak to 8vMatt here on this forum as he does a group buy for the uprated LED headlight switch.
Link below.
http://the-corrado.net/showthread.php?96213-2017-Headlight-Switch-group-buy-is-a-go!/page10
Hope this helps
Si
Edited by vw rule
Just found this on the VW Heritage site,
not in the Corrado section but in the MK2 Golf section,
it's the rear stub axle dirt / dust plate covers that slide over onto the inner end of the stub axle flange,
they help to stop any dirt getting into the hub bearing or damaging the bearing seal.
The part number is 191-501-639A and is under the MK2 Golf section but this item fits the Corrado as well.
Cost of the above item is £7.10 per each.
Don't forget to check the MK2 Golf section for Corrado parts as well,
as some are listed there.
Si
OEM part n.o
191501639A
Corrado 1992 to 1995 with ABS
Drawing 5 position 18
[ATTACH=CONFIG]89675[/ATTACH]
OEM part n.o
191501639A
MK2 Golf 1988 to 1992
Drawing 2 position 19
£4.50 from VW Heritage
Tried up loading the second photo link,
but at the moment the forum is being weird.
You'll have to check with VW Heritage on stock of the first item for the Corrado i.e with ABS as back along they weren't in stock.
They were only keeping this part for NONE ABS 1984 to 1988 to 1992
Hope this helps.
Si
Edited by vw rule
They're not the correct part for ABS fitted Corrado. The correct part is the same as the Passat, which is still available but under a different part number. If you do a search you should find the part number and price as I bought some about 6 months ago.
Edit: Part number is V3A0 501 639 - £4.42 each.
Edited by seanl82
Correct . The MK 2 part is a lot bigger than the Corrado part .
Hi guys yeah I know it's the part number for the none ABS item, hence putting up the first photo link, I tried to find the correct part number but couldn't find it on Classic Parts :lol::salute:
I was hoping someone would post up with the correct part number, thanks guys much appreciated.
Thanks again
Si
Cold start valve 1.8 & 2.0 16v Corrado
and possibly Golf and some Audi's.
026 906 171A £149 euros
Gasket for above valve and possibly for
the alloy connection pipe below.
050 906 179 £1.49 euros
Alloy Connection pipe from inlet manifold
to cold start valve
(this is bolted to lower section of manifold)
027 906 175D £47.96 euros
Square support bracket for 16v inlet manifold
has 4 bolt holes
027 133 231H £19.96 euros
1.8 & 2.0 16v Corrado / Golf
Plastic bracket for fuel injector pipes
027 133 689R £2.39 euros
2.0 16v Corrado
Fuel pressure regulator
034 133 534F £419 euros
Large jubilee clip for air intake pipe off metering head (for KR & 9A eng)
N024 521 2 £3.69 euros
Main Rubber intake hose ( 45 degree angle )
Fits between throttle body face and large plastic intake pipe (only for KR & 9A 16v engines)
027 133 648 £71.95 euros
Air intake plastic pipe from air filter to throttle body,
fits to rubber intake hose above (for KR & 9A eng)
027 133 373J £47.96
2.0 16v (9A) air flow metre head
051 133 471AX £869 euros
Hex bolt ( ANTI MAGNETIC BOLT it should be)
for Differential fuel pressure regulator/governor (KR & 9A eng)
026 133 483A £2.89 euros x2 neeeded
1.8 & 2.0 16v original air filter box
(Top / bottom part)
051 133 837A £199 euros
Available at Classic Parts if you order through VW Heritage.
Hope this helps
Si
Edited by vw rule
VR6 Corrado
Left side radiator plastic air guide
535 121 283J £29.95 euros
VR6 Corrado
Right side radiator plastic air guide
535 121 282A £54.95 euros
4 cyl Corrado
535 121 283A £14.95 euros
4 cyl Corrado
535 121 284D £74.95 euros
All in stock at Classic Parts.
Hope this helps
Si
1) Main wiper frame for RHD Corrado
536 955 605 £65.95 euros
2) Long wiper linkage for RHD Corrado
536 955 326 £24.95 euros
3). *****************************
Small wiper linkage for RHD Corrado
536 955 325 SHOWING AS OBSOLETE
Hopefully this item will be available again
4) Wiper crank arm
(allows fitment from motor to linkage)
RHD and LHD looks like same item for both.
535 955 121 £4.69 euros
5) Left wiper spindle complete with bearing,
for RHD Corrado only
536 955 215 £21.96 euros
All in stock at Classic Parts if you order through VW Heritage.
A part from item 3 which is still obsolete since late 2016 / early 2017
Hope this helps
Si
Edited by vw rule
Main wiper frame for LHD Corrado
535 955 605 25.95 euros
Small wiper linkage for LHD Corrado
535 955 325 £2.59 euros
for LHD Corrado only
535 955 215 £11.95 euros
Right wiper spindle complete with bearing,
535 955 216 £11.95 euros
Hope this helps
Si
Edited by vw rule
Earlier on today I ordered a few more parts
for my Corrado and checked a part number with Heritage that I found on the Classic Parts website, it looks like this item in question has possibly been reproduced by Classic,
not sure how many are in stock or how long it'll be available for.
The item is the rear VW Emblem (Chrome Special)
Part number is: 357 853 601WM7
Cost roughly £17
The badge is 70mm in diameter,
with the rubber backing it's 75mm
Hope this helps
Si
Cost roughly £17
Hope this helps
Si
£14.36 plus VAT on the badge
No worries, like I say grab them whilst you can as I'm not sure how long they'll be available for.
I've seen these new badges go for £45 or even £50 on Ebay, back in 2012 and 2014
Si
Si
Stockpile...... :) sure I have space in the loft.
Also both the left and right plastic air guides, that help to ventilate the front brakes
on the later Corrado's are available again through VW Heritage.
The left side has been available for the last year or so, which is part number:
535805825D £54.95 from 1992 to 1995
The right side one is also available now,
Heritage don't keep it but can order it from Classic Parts for you.
Also possibly the early style air guides are available, speak to George as I spoke to him yesterday at VW Heritage he'll confirm if they are, regarding the early ones
Si
Edited by vw rule
I did have space :lol:
I think the house foundations are sinking :lol::lol:
Edited by vw rule
i paid £40 for a new rear chrome badge a few months ago from a parts supplier in germany
Yeah it's scary really what some of these new parts sell for from third parties, so to speak.
But on a positive note at least you've managed to find a new one Ger040,
it can be a mind field trying to find some of these new parts.
Si
Edited by vw rule
Si
its just a fact that the parts for these cars are drying up and parts are becoming more expensive as time passes. if I had the money in would be buying multiples of everything and in the future sell them for extorionate amounts of money and retire to the sun!!!
The MK3 Golf fuel neck repair panel is being reproduced by VW Heritage, looks like 1000 are being made but are on back order for now until complete. No completion date has been given only that they are due in the next two to three months or so.
Part number is: 191 803 483
Cost is £26.50
http://the-corrado.net/showthread.php?108232-Drivers-rear-inner-and-outer-wing
We can possibly use this on our Corrado's if our old panels are rusted through, which seems to be a common area now on the Corrado.
Si
Hi,
You are correct we are reproducing that part at the moment. Interested how you know how many we are making though :-)
Price - that is not the price, its a new part for us that we have made. That price was the price from when we had genuine on stock. It will get a new price in accordance with the new cost and tooling costs which will also have to also be factored in. This would usually be done when we got the final invoice once the parts have shipped to us.
Due date - unfortunately 2-3 months is not going to happen and unrealistic, we are still awaiting the first sample and unfortunately as much as this company make really nice quality products, they are not a fast company to deal with.
If anyone wants any updates then feel free to drop me a pm later on and i will update on the parts progress.
Thanks Anna yeah I spoke to Julian earlier on today, he told me roughly how many were in the pipe line to be made so to speak.
Cheers
Si
Cheers
Si
Ahh got you. I was like, how does he know that lol
I will update on here when we get news. We will probably be looking for someone to test fit the sample once it arrives. Its the same manufacturer that did the VR6 backing plates we did
