corrado_sunderland 0 Posted December 2, 2010 i had the bonnet popeed up incase bat went flat and sadly snow has shut it with weight and my locks a flushed and battery is now dead :( any ideas how to get he open? Quote Share this post Link to post Share on other sites
firecracker 0 Posted December 2, 2010 can you access under the car and try and grab the cable where its attached to the front valance,a sharp pull on that normally release the catches? easier if you can access through the front grill nr where the horns are, gd luck. Quote Share this post Link to post Share on other sites
jamiehamy 0 Posted December 2, 2010 You'll have to break something...probably the grill. I had the same problem, but fortunately my grill is not screwed in at the top as it fits snug and the tabs were broken off. I removed the grill and basically had to squeeze my hand through the sides of the radiator to get at the catches. If i remember rightly, if you can get a purchase on one of them, the other will unlock too - I'm sure the drivers side one is easier to get to as well as being the one that will unlock the other side if you get to it. Once you feel the catch (the bit where the cable runs through is fine), it should be pushed towards the drivers side. Will take a bit of force. Will be a lot easier if someone is gently pressing down on the bonnet and joogling it. As i say, the worst part is getting the grill off. A hacksaw blade to the bottom part will take the tabs off and they can be superglued back at a later date. Hacksaw at the top should work too, not sure about the angles tho. Good luck! Quote Share this post Link to post Share on other sites
buttles 0 Posted December 2, 2010 Or the guide in the Wiki? Quote Share this post Link to post Share on other sites
bristolbaron 10 Posted December 2, 2010 rip out grill pull cable - drivers side buy new grill Quote Share this post Link to post Share on other sites
Wullie 1 Posted December 3, 2010 Clear the snow first. Quote Share this post Link to post Share on other sites
corrado_sunderland 0 Posted December 3, 2010 You'll have to break something...probably the grill. I had the same problem, but fortunately my grill is not screwed in at the top as it fits snug and the tabs were broken off. I removed the grill and basically had to squeeze my hand through the sides of the radiator to get at the catches. If i remember rightly, if you can get a purchase on one of them, the other will unlock too - I'm sure the drivers side one is easier to get to as well as being the one that will unlock the other side if you get to it. Once you feel the catch (the bit where the cable runs through is fine), it should be pushed towards the drivers side. Will take a bit of force. Will be a lot easier if someone is gently pressing down on the bonnet and joogling it. As i say, the worst part is getting the grill off. A hacksaw blade to the bottom part will take the tabs off and they can be superglued back at a later date. Hacksaw at the top should work too, not sure about the angles tho. Good luck! all the tabs were knakard on mine anyway, i literally pulled it today and it fell off :lol: just hope intercooler dont make it any harder to get at but thanks for he help guys :grin: Quote Share this post Link to post Share on other sites
Rustynuts 0 Posted December 8, 2010 Are all your locks flushed? How about getting in through the boot, been there done that! :roll: Quote Share this post Link to post Share on other sites
corrado_sunderland 0 Posted December 9, 2010 Are all your locks flushed? How about getting in through the boot, been there done that! :roll: typ locks are flushed and boot lock doesnt open from key, key fits in but nothing happens other that that :lol: Quote Share this post Link to post Share on other sites
