jamin 0 Posted February 27, 2011 Hi all, My C has started to play up when it starts. The engine has to turn over quite a few times before it finally fires into life. Once started it runs fine, idle is fine, accelerates fine etc. It seems that the longer it sits around, the longer it takes to start, it sounds like a fuelling issue to me, could it be the pump? Surely if it was the pump then it wouldn't run properly? Any ideas on what to check first? This week there was an intermittent 'squeak' coming from the engine bay when running from cold, but soon stops once warmed up, maybe its related...I dont think I have mice in the garage! Thanks in advance Quote Share this post Link to post Share on other sites
v8rumbler 0 Posted February 27, 2011 Hi Mate The 1st thing to check is the battery- how old is it? How many volts is it showing whilst not being used and how many during cranking? Quote Share this post Link to post Share on other sites
jamin 0 Posted February 27, 2011 Battery is fairly new, the engine turns over fine, so its not the battery, it just doesn't fire. Once it does fire it runs fine. Thanks. Quote Share this post Link to post Share on other sites
moneypit23 0 Posted February 27, 2011 Sounds like what happened to mine. It was something to do with a loss of pressure due to worn piston rings, something like that. It got progressively worse and the day it was due to go to PSI it took about half an hour to get it started. Quote Share this post Link to post Share on other sites
jamin 0 Posted February 27, 2011 This is not what I want to here at all! I do think my rings are on the way out though. I get some blue smoke on hard acceleration or when I suddenly come of the throttle - found that out at the 'ring last year. Quote Share this post Link to post Share on other sites
moneypit23 0 Posted February 27, 2011 It wasn't what i wanted to hear either. I was working miles away and i'd only had it about 6 weeks and while it was in i got the old 'might as well do the chains as well'. Bad times. Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted February 27, 2011 Might be something simple though check the less costly things first fuel filter etc and work from there. Good luck fella. Moneypit23's car was a very random one no blue smoke, or any major signs it was just really hard to start it. The old girl (the car not the missus :-p) is doing well after the work though Jon Quote Share this post Link to post Share on other sites
jamin 0 Posted February 27, 2011 Cheers guys, I'll look at fuel filter/pump first and go from there... Quote Share this post Link to post Share on other sites
Richardshoes 0 Posted February 28, 2011 could be any number of things Static and ignition timing spark plugs firing Injectors Quote Share this post Link to post Share on other sites
fendervg 30 Posted March 8, 2011 I had exactly the same symptoms and tracked it down to a faulty fuel pressure regulator - not too expensive and easy to replace - it's the silver cylinder that sits at the front of the fuel rail on the off side. Worth a try. Quote Share this post Link to post Share on other sites
4eyes2wheels 0 Posted October 2, 2011 jamin - did you resolve this issue? I have a similar sounding problem - car left standing for a week or overnight or simply for 5 hours and it's a struggle to start. Needs a lot of gas pedal and a bit of spluttering (like when the crank position sensor is knackered) but it gets going and a bit of revving and we are all fine. Subsequent starts are fine - either immediately afterwards or leave it alone for and hour or so. I've cleaned the ISV, replaced the blue temp sender, MAF, lambda sensor (for other various reasons around using lots of fuel) and am wondering if it's the fuel pressure regulator. And if it was that would I see anything on VAG COM? as ever, advice welcome - especially from jamin and fendervg Quote Share this post Link to post Share on other sites
floppyman 0 Posted October 3, 2011 Vag com will not show any info that can help diagnose a faulty fps... One good way is to disconect the vacuum pipe that goes to the fps and smell it :) ... If you smell fuel the that fps is leaking (no good). And like its been said before.. Its not an expensive part. Just make shure you get the right one (golf vr6 doesnt work) Quote Share this post Link to post Share on other sites
dannyboy 0 Posted October 4, 2011 if its a valver(you havent metioned what engine you have) check the cold start device,others check the fuel filter as said earlier.Have you checked for spark? Quote Share this post Link to post Share on other sites
4eyes2wheels 0 Posted October 7, 2011 (edited) if its a valver(you havent metioned what engine you have) check the cold start device,others check the fuel filter as said earlier.Have you checked for spark? It's a VR6, I have spark as it fires up but needs a lot of right foot to get it to settle down. ---------- Post added at 08:42 PM ---------- Previous post was at 08:41 PM ---------- Vag com will not show any info that can help diagnose a faulty fps... One good way is to disconect the vacuum pipe that goes to the fps and smell it :) ... If you smell fuel the that fps is leaking (no good). And like its been said before.. Its not an expensive part. Just make shure you get the right one (golf vr6 doesnt work) Thanks - I'll give that a go! Golf VR6 doesn't work you say? This eBay item suggests it can be VW GOLF MK3 2.8 VR6 ALL , MK4 R32 and Corrado VR6 2.9. :shrug: Edited October 7, 2011 by 4eyes2wheels Quote Share this post Link to post Share on other sites
floppyman 0 Posted October 7, 2011 Yes they are different... Corrado has more fuel rail pressure... Cant remember now but I think corrado has 5bar fps and the golf is 4bar... They fit... But you will notice poor performance Quote Share this post Link to post Share on other sites
floppyman 0 Posted October 7, 2011 Sorry 4eyes2wheels.... I might be rong. Went out to check mine it is 4bar. Checked eurocarparts and for the golf is 4 bar aswell. And... 80 pounds bosch part... And you can get 20% off online Quote Share this post Link to post Share on other sites
VeeDub Geezer 0 Posted October 7, 2011 Mine was struggling to start after being left over night. Just fitted new spark plugs and leads and it started on the button! Worth a try? Quote Share this post Link to post Share on other sites
4eyes2wheels 0 Posted October 8, 2011 Mine was struggling to start after being left over night. Just fitted new spark plugs and leads and it started on the button! Worth a try? Leads are less than two years old and plugs are a year I think - worth a go though! ---------- Post added at 04:17 PM ---------- Previous post was at 04:16 PM ---------- Sorry 4eyes2wheels.... I might be rong. Went out to check mine it is 4bar. Checked eurocarparts and for the golf is 4 bar aswell. And... 80 pounds bosch part... And you can get 20% off online Nice one - I'll take a look at ECP when I've got some cash together. Quote Share this post Link to post Share on other sites
mattwelcer 0 Posted October 19, 2011 AFAIK Early Golf VR6 4bar FPR Later Golf VR6 3bar FPR Corrado VR6 4bar FPR Quote Share this post Link to post Share on other sites
fla 9 Posted October 20, 2011 if your sparks are new, just check that they are visually ok, which i magine they would be. Does the rev counter needle jump around sometimes? If so, it may point to your ecu relay on its way out. A more pricey consideration would be the crank sensor - best to try and borrow a working one to rule it out. In summary the things to check (in no particluar order) are: ecu relay 109 fuel pump relay 167 FPR Fuel pump crank sensor FPR needs to be removed carefully - its a bit tricky and then refitting is also a similar annoyance. Quote Share this post Link to post Share on other sites
liamtg60 10 Posted October 23, 2011 Hi sorry to hijack thread but wher the hell is the cold start device on a valver cos think mines done for? Cheers Quote Share this post Link to post Share on other sites
