JayGT
Wiper Motor Cover
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=140518296127&ssPageName=STRK:MEWAX:IT#ht_1075wt_1139
Any body seen one of these before? Never knew VW made one and much prefer one of these to a full length scuttle cover.
I'll have credit for that little find back in early 09, stick a mk 2 Goof scuttle cover on (requires some cutting for the washer fluid tubes and earth strap and some heating up to get it to sit nicely) and you have a very OE looking full scuttle option.
Don't buy the ebay item it's more expensive than a new one from VW! Should be around £8 inc VAT for one.
The brake cooling duct 'ears' are also less than £5 a piece from the stealers too.
Other plastic bits you can also fit are the wishbone leading edge stone deflectors from the '93 to '96 Passat too, the only fit the 4 cylinder cars but again help to keep the amount of crud getting flicked around the by the driveshafts down.
Still trying to find a cheap way of fitting a complete undertray but that looks like a scrappy job only.
Can anyone provide the part number for the motor cover please.
Sent from iPhone 4 using Tapatalk
Have you the part number for the golf scuttle panel ? Please
Yep 192 819 415C should be around £35 inc VAT.
It does need heating up to get it to fit properly as the 'rado one is just a little wider, make sure you get plenty of extra clips to hold it down too.
Not got a photo of mine yet, trialed it on the 16vG60, but best bet is to use a fresh stanley blade to cut the plastic to fit where required. If you have a jetex pollen filter it's a very tight fit and the plastic is quite brittle so be careful at that end.
