fendervg 33 Posted November 1, 2019 That's pretty much it - I couldn't find the part# any more for the connector, but it's the same as the Mk3 sunroof and possibly the heated seat switch - flat 4-pin. I would definitely advise getting the repair wires with the pins on the end. If you can get hold of some posi-tap connectors, they are way better than scotch-lok. Quote Share this post Link to post Share on other sites
Keyo 49 Posted November 1, 2019 fendervg said: That's pretty much it - I couldn't find the part# any more for the connector, but it's the same as the Mk3 sunroof and possibly the heated seat switch - flat 4-pin. I would definitely advise getting the repair wires with the pins on the end. If you can get hold of some posi-tap connectors, they are way better than scotch-lok. From what I see the cables only come in 50 cm ? https://www.ebay.co.uk/itm/Genuine-Repair-Wire-x5-VW-Audi-Skoda-SEAT-000979133E-New-genuine-part/113928235629?hash=item1a86a6ea6d:g:Rf4AAOSwgZtdqee8 Are they too short shall I just get the crimps instead ? https://www.ebay.co.uk/itm/Audi-VW-Skoda-Seat-Porsche-10-x-Wiring-Crimp-Repair-Terminals-Pins-000979133E/223507235310?hash=item340a11c1ee:g:w~MAAOSw5dlaFmbv Quote Share this post Link to post Share on other sites
delfinis38 1 Posted November 1, 2019 (edited) Two that go to the cig for illumination, and ground will be right length, even two long. You will need to join a wire to go to the sender and glovebox light / batt. I guess it would be cheaper and neater to just buy the connector ends and electrical wire. I only paid a few quid for the yellow wire and connector Edited November 1, 2019 by delfinis38 Quote Share this post Link to post Share on other sites
Keyo 49 Posted November 1, 2019 delfinis38 said: Two that go to the cig for illumination, and ground will be right length, even two long. You will need to join a wire to go to the sender and glovebox light / batt. I guess it would be cheaper and neater to just buy the connector ends and electrical wire. I only paid a few quid for the yellow wire and connector Nice one mate. Quote Share this post Link to post Share on other sites
fendervg 33 Posted November 2, 2019 000 979 021 (000979021): 0.5mm wire 000 979 133 (000979133): 1.0mm wire 000 979 225 (000979225): 2.5mm wire Quote Share this post Link to post Share on other sites
Keyo 49 Posted November 6, 2019 Hi everyone, Stumbled across this company if anyone is thinking about making up some battery and oil gauges. You can choose your own colour for the Corrado screen https://moman.pl/en/home/942-2066-volkswagen-corrado-additional-indicators.html#/119-design-design_1/190-lighting_color-blue Quote Share this post Link to post Share on other sites
paddy26 3 Posted November 7, 2019 I've used them before for corrado and mk3 golf and they are good quality. \Paddy Quote Share this post Link to post Share on other sites
