MarkCorrado
Drivers side door problem!
I can't open my drivers side door its has been getting harder to open recently and now im stuck with having to use my passenger door to get in. The handle has come really loose and im guessing its just not grabbing the internal stuff.
Is this an easy fix or do i need a mechanic to solve the problem.
Cheers.
Might just be the handle securing screw come loose, it's on the end of the door, usually a left had thread on the driver side.
PM me for a kit IF you need one.
Dave
Edit - oh do you mean the pull part of the handle or the main body is loose?
Edited by daves16v
Dave
Just had a look at it, its the handle that's really loose not the main body. Is that fixable or do i need a kit?
Thanks
Mark
Remove the securing screw, then you should be able to remove the handle slightly enough to be able to see if the striker has broken.
