MarkCorrado 0 Posted April 7, 2011 I can't open my drivers side door its has been getting harder to open recently and now im stuck with having to use my passenger door to get in. The handle has come really loose and im guessing its just not grabbing the internal stuff. Is this an easy fix or do i need a mechanic to solve the problem. Cheers. Quote Share this post Link to post Share on other sites
robrado974 1 Posted April 7, 2011 need the door handle repair kit mate . do a search on here and you will find it . regards rob Quote Share this post Link to post Share on other sites
MarkCorrado 0 Posted April 7, 2011 Thanks for the help dude. Quote Share this post Link to post Share on other sites
daves16v 1 Posted April 8, 2011 (edited) Might just be the handle securing screw come loose, it's on the end of the door, usually a left had thread on the driver side. PM me for a kit IF you need one. Dave Edit - oh do you mean the pull part of the handle or the main body is loose? Edited April 8, 2011 by daves16v Quote Share this post Link to post Share on other sites
MarkCorrado 0 Posted April 8, 2011 The main body is really loose! Quote Share this post Link to post Share on other sites
MarkCorrado 0 Posted April 8, 2011 daves16v said: Might just be the handle securing screw come loose, it's on the end of the door, usually a left had thread on the driver side. PM me for a kit IF you need one. Dave Edit - oh do you mean the pull part of the handle or the main body is loose? Just had a look at it, its the handle that's really loose not the main body. Is that fixable or do i need a kit? Thanks Mark Quote Share this post Link to post Share on other sites
dragon green 5 Posted April 8, 2011 Have you got the White plastic clip in the photo ? Still available,and usually in stock ! Pence to buy ! Quote Share this post Link to post Share on other sites
daves16v 1 Posted April 9, 2011 Remove the securing screw, then you should be able to remove the handle slightly enough to be able to see if the striker has broken. Quote Share this post Link to post Share on other sites
