4eyes2wheels 0 Posted July 2, 2011 One fog light has not worked for ages. I decide to change the bulb - easy right? Oh no this is a Corrado remember! So of course the fog light cluster screws are totally rusted up. :bonk:I eventually get that resolved. Get the cluster out, unclip the clips whip out the old bulb stick the new bulb in, reassemble, stick the lights and . . . nothing. :epicfail: The other one works. :scratch: Time for a cup of tea! Quote Share this post Link to post Share on other sites
andy 0 Posted July 2, 2011 Always test the bulb before re-assembly......, hindsights a wonderful thing! My screws were rusted similarly last week when I had mine out, the bigger problem was the fact that the reflector was so rotten there wasn't enough metal left to mount the bulb! Doh! Can't say I've ever used them anyway! Quote Share this post Link to post Share on other sites
4eyes2wheels 0 Posted July 2, 2011 I'll get back out there and test bulbs back and forth between both lights. I barely ever use them either but it's one of those things that gnaws away at me knowing that only one of them works! ---------- Post added at 04:13 PM ---------- Previous post was at 03:06 PM ---------- Right - All bulbs work in one fog light and no bulbs work in the other one. So, me thinks there must be something wrong with the wiring. I have no multi meter but if I got one what am I looking for? Quote Share this post Link to post Share on other sites
dragon green 5 Posted July 2, 2011 If you havent got a multi-meter,you could take both foglights off the car,plug the one that doesnt work,into the side that does work. If it now works, its the wiring to the foglight,(the car side) If it doesnt work,its the wiring on the foglight side ! Its most likely a corroded plug,pull apart,lots of WD40 and clean pins. good luck Quote Share this post Link to post Share on other sites
4eyes2wheels 0 Posted July 2, 2011 Ah - good idea! Thanks I'll give that a go! Quote Share this post Link to post Share on other sites
SIMONG 0 Posted July 7, 2011 i had a similar prob with my indicator, it was the wire whcih goes into the the connector had snapped just as in joined the connector Quote Share this post Link to post Share on other sites
4eyes2wheels 0 Posted July 7, 2011 Thanks for the tip! Just need to muster the enthusiasm to have a look, it's only a foglight after all. Quote Share this post Link to post Share on other sites
boost monkey 0 Posted July 8, 2011 it will probably be oxide/corrosion in the connector or wiring. Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted July 8, 2011 :lol: got this exact same issue. One fog light hasnt worked since taking the bumper off i think (didnt notice it until i put bumper back on, so hopefully its the bulb), but like you the screws are fooked. Quote Share this post Link to post Share on other sites
