jhey 10 Posted August 12, 2011 Hey guys, I've just gone to throw some new H4s in as my offside light seems to be dimmer. My nearside top bolts are bearable and come off but the one lower in the slam panel and the complete set of offside bolts are rusted/rounded/screwed(no pun intended) Any ideas on the best way to remove these and where to get replacement in the UK? Had thought of chiselling the top and using a flathead? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 13, 2011 Take the slam off for better access and maybe try pliers / irwins but mask off so you don't scratch the slam panel. Stainless steel is the only way to go really... I use No. 10 x 16mm for the tops and I think the middle ones are 25mm - Screwfix sell them Quote Share this post Link to post Share on other sites
jhey 10 Posted August 13, 2011 Any tips on removing the slam panel, a link maybe? Quote Share this post Link to post Share on other sites
t700bes 1 Posted August 13, 2011 Hey Jhey... errm at the risk of sounding like a dick.. it was the first link that google brought up gave a direct howto on how to remove it!! Its only a few bolts.. http://letmegooglethatforyou.com/?q=corrado+remove+slam+panel Quote Share this post Link to post Share on other sites
jhey 10 Posted August 13, 2011 Yes I am capable of using Google, just their might of been something more useful than that. I am not the most competent with car mechanic soo .... risky manouevre ;) Thanks anyway. Quote Share this post Link to post Share on other sites
beaky 10 Posted August 13, 2011 I had the same problem, took the air filter/battery out and used a small hacksaw to cut a flat head screw groove, lots of wd40 and it's out. Quote Share this post Link to post Share on other sites
Redfox 10 Posted September 11, 2011 Had the same problem on my headlights, as the third screw that sits deep were really susty. I gave it som wd40, found a almost fitting philips screwdriver, a little dap with a hammer, and then a little larger screwdriver preddes somewhat hard from above. They came loose. Replaced with stainless philipsscrews. Cheers, Redfox. Quote Share this post Link to post Share on other sites
nocrap 0 Posted September 11, 2011 the only way i could get mine out was to use a long drill and some patience Quote Share this post Link to post Share on other sites
Ruggy 10 Posted September 12, 2011 I had this problem last weekend. The nearside bulb you can do without removing the headlight, little bit cramped for space but not too difficult. The offside bulb, you need to move the airbox out of the way, then again you can get access to the back of the headlight to change the bulb. Quote Share this post Link to post Share on other sites
