24V Renshaw 0 Posted December 5, 2011 Exactly what I want! Cheers mate. Jay Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted December 5, 2011 Yeah the spindles would be brilliant if we can pull that off! :D Yeah, Graeme's definitely looks right there. I like a uniform gap around the arch like that and the obvious suspension travel is confidence inspiring! I hate it when Corrados are so low the rear wheels start to push forward, making the arch gap look inconsistent. It reminds me of an old Hydroelastic suspensioned Austin Metro that's collapsed!! Having had the H&R/Koni duo on mine originally, I can second Tony Ack's comments on it being too hard round town, but the pay off is it comes together at faster speeds out on the open roads. It feels sublime :D My V3s have the best ride comfort of any suspension I've yet experienced in a Corrado, but it runs out of travel very quickly and you get a 911 nose bounce, which irritates me no end. A quick fix would be longer springs from KW but long term I need those drop spindles :D Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted December 5, 2011 Looking forward to getting them I must admit. Fitted new poly front cross member bushes tonight. Having done it in the past and remember it being tricky using a press, I put a bit of thought into it.... Removing the old bushes was easy, hacksaw off the top and they just pop out... Then once the new bush is copper greased up, simply put a large washer/plate on top of it, feed a long bolt through the washer, bush and subframe. On the opposite side of the subframe put a sleeve large enough to fit over the bush when it pops through and another plate/washer and a nut. Tighten the nut onto the bolt and as easy as pie they pop in. Did all four in about 10 minutes :) Then fitting the smaller mount the principle is the same, nuts, large washers and bolts to press them in :) Will see what difference they make tomorrow on the way to work... Jay Quote Share this post Link to post Share on other sites
StueyB 0 Posted December 8, 2011 Loving the angle of attack. Defo trying this method once i've ordered bushes. Even with a main dealer sized press, we struggled to change these bushes for powerflex ones of my brother's golf. Many a bad word was said after they slid/popped out of the press sideways for the umpteenth time. Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted December 8, 2011 Yeah I remembered doing mine before with a press and them being like slippery eels.. Hence my method with the washers, it was soooo easy :) Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted December 9, 2011 Didn't even know about those bushes, i better add them to my list :lol: Quote Share this post Link to post Share on other sites
boost monkey 0 Posted December 9, 2011 3Cm, you actually crack me up! :lol: Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted December 9, 2011 i'm learning as i go really, only got into DIY mechanics as otherwise i couldn't afford to keep the corrado. Was 28yrs old when i changed my 1st brake pads, always took cars to a garage before corrado. Am slowly taking it to bits and renewing most of it. :lol: Quote Share this post Link to post Share on other sites
StueyB 0 Posted December 9, 2011 Yeah I remembered doing mine before with a press and them being like slippery eels.. Hence my method with the washers, it was soooo easy :) Any chance of a picture of the washer setup laid out in separate bits...? Gotta love a good homemade tool. Quote Share this post Link to post Share on other sites
boost monkey 0 Posted December 9, 2011 2 fat washers, bolt, nut. Lather rinse and repeat for other ones :salute: Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted December 9, 2011 I will try and "reconstruct" all the bits again in an assembly style for you on the bench. The only bit Boost Monkey missed out is the sleeve to allow the bush to pop through. Jay Quote Share this post Link to post Share on other sites
StueyB 0 Posted December 9, 2011 Yeah, the sleeve is the only slightly challenging bit I wasn't sure about. Thanks Jay. Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted December 9, 2011 I just had a piece of metal tube lying about which fitted the bill perfectly, so I can put the details up of it. Jay Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted December 11, 2011 After a trip to the breakers on Saturday to lend a hand to Andy (C5 OEM) and collect a lamdba sensor connector, I noticed a little dribble of oil under the car and could smell burning oil while driving. So I had a look around and thanks to the fact I had cleaned up and painted the front of the engine the other week while I had the chance, I noticed the oil (virtually clear) trickling from the oil pressure sensor. So a new one purchased on the way home and fingers crossed it will stay dry :) Been endlessly swapping around engine mount inserts of different stiffnesses all week while I finalise the hardness for the group buy, so much so that its now a standing joke with the wife that every evening I am going out to "play in the bushes". Thankfully I have now settled on the perfect balance of holding the engine nice and secure, but not adding any vibration to the car. I took it too far and there was a lot of cabin vibration so I am happy I have found the right level now. Jay Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted December 11, 2011 Good work on those bushes- looks easy as pie! Here's a pic of mine on Koni/H&R suspension with standard wheels. I love the setup- can feel a little harsh on poor surfaces, but overall they are superb. Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted December 11, 2011 I have them in my hands now, need some cleaning up but for the price they are great. No leaks etc.. Question is, do I get the Koni's powder coated the original Yellow, or do I get them black so they look OEM. Likewise with the springs. Green or OEM Black? Jay Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted December 11, 2011 LOL. I knew you would say that Gareth. I am with you to be honest, quite like the idea of the "stealth" lowering. Jay Quote Share this post Link to post Share on other sites
OSV 0 Posted December 11, 2011 Got to say that if I was starting over i'd seriously look at shocks and springs too, especially in low maintenance non eye catching black, says Mr Yellow spring Inox KWs LOL. Quote Share this post Link to post Share on other sites
James. 9 Posted December 11, 2011 (edited) Second here for black. Though I am biased in an OE kind of way. Looking to replace the suspension on the 8V next year with KW sports. Trouble is that they're pink ! You can be sure as mustard that they'll be getting a good Johnny Cash shake down before being installed though ! Edited December 11, 2011 by James. Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted December 11, 2011 I think black is what these will be getting, won't look as "sexy" in the inner arch shots but will be nicely hidden when you look through the wheels. :) Quote Share this post Link to post Share on other sites
Portent 0 Posted December 11, 2011 Also voting black. But I pefer understated styling. Quote Share this post Link to post Share on other sites
Purple Tom 0 Posted December 11, 2011 Black all the way for definite - subtle is definitely the order of the day for a nicely modified car I reckon :) Thanks for the hard work on the engine mounts, really looking forward to getting them on the TDi! Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted December 12, 2011 They are definitely going black. Maybe with a subtle Koni sticker on them somewhere :) Your not wrong about the hard work with the mounts. I have changed both the front and the rear mount every night for the last week or so. I have actually ending up pulling a muscle in my chest from doing it! Jay Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted December 13, 2011 Think I have found myself a powder coaters and the bloke is a total petrol head so I am looking forward to getting the suspension done. Are OEM struts and springs, gloss or Satin black? Quote Share this post Link to post Share on other sites
