budhilton 10 Posted November 12, 2011 (edited) Any ideas what should be in this hole and where to get whatever it should be? Also whilst I am on how do you remove the demister vent strips on top of the dash? [ATTACH=CONFIG]50077[/ATTACH] Thanks Andy Edited November 12, 2011 by budhilton Quote Share this post Link to post Share on other sites
floppyman 0 Posted November 12, 2011 There should be a switch... For the boot light? Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted November 12, 2011 (edited) It's a little spring-loaded popper, to lift the boot slightly so you can get your fingers underneath easily to lift it. Still available from VW for less than a tenner. Just remember to order the securing piece that screws on, as it doesn't come with the other part. There is also a little rubber piece that pushes onto the end, but there are 3 different versions of this- VW will be able to tell you which one when you give them your reg ;) 535827761 Popper 535827765 Threaded securing plate Edited November 12, 2011 by CazzaVR Quote Share this post Link to post Share on other sites
dragon green 6 Posted November 12, 2011 Im sure it the "boot popper " Beaten to it ! But it's about £7 Quote Share this post Link to post Share on other sites
P3rks 11 Posted November 12, 2011 I never knew this.. Both my C's just had a blank hole so I assumed it was a blank! Quote Share this post Link to post Share on other sites
budhilton 10 Posted November 12, 2011 Yeh full marks to Cazza for the quick response. The boot light works so it's not that and my god a part that I can actually get from VW result. Cheers gents very helpful as usual Andy Quote Share this post Link to post Share on other sites
dragon green 6 Posted November 13, 2011 Finally found my spare one Quote Share this post Link to post Share on other sites
Yandards 0 Posted November 13, 2011 Boot light runs off the boot lock mechanism, simply flick the boot catch over with the boot open and watch the light go out.. Quote Share this post Link to post Share on other sites
VW_OwneR_85 2 Posted November 13, 2011 ahhh i thought it was a switch, everydays a skool day ;) Quote Share this post Link to post Share on other sites
StueyB 0 Posted November 14, 2011 Boot popper as said above. Likely case here is its broken in the past and not been replaced, just simply removed. From my experience they tend to break due the boot not being opened for a long time (i.e. if car has been standing), seizing up under compression and then exploding the first time you open the boot for a while. Rendering the popper useless. Quote Share this post Link to post Share on other sites
