StueyB
Breaking: Late Spec 2.0 8v - Flash Red - *Updated 2nd listing half way down PG1*
Hi Stu, you've already had a pm from me regarding the front splitter but thought I'd put dibs on it in the breaking thread to secure. Also interested in the os side of the flimsy drainage tray that sits above the wiper motor/linkage and if you have just a late spec ns headlight glass (not complete light) I'll have your arm off for it!
Ed, all messages received. Detailed pm heading your way.
Hi stu do you still have the roof mouldings. I got my number plates recess in the bodyshop at the moment and might get these sprayed aswell will you take 20£ posted please ? Got a contact number i can get your on ?
DeanJames, still have roof mouldings.
Happy to do them to you for £20 but plus postage, due to size and fragile nature.
Let me know what you think.
I'll take both of:
Front Wings 40.00 each (mint & solid, no rust what so ever)
.. this from a late model right?
I'll take both of:
Late model indeed.
Pm replied to with pics.
Drivers Headlight 45.00 (Mint, No chips or scratches)
Question does the adjuster etc work as it should mate eg. moves the reflector and isnt broken inside ?
Will have a play with it next time I'm down the unit and let you know, my guess at the mo is yes but will confirm.
---------- Post added at 9:33 PM ---------- Previous post was at 9:32 PM ----------
Hello mate, got a pic of the VR6 badge? If you're still speaking to me that is :lol:
Nick, I will dig one out shortly and yes I'm still speak to you...:smurf:...just.
Hey Dan,
Afraid a friend has just taken that for his car.
Anything else I can help you with..?
Regards,
Stu
Thank you! (on both :lol:) I'll have another one of those speaker connectors off you when I'm next round, the crossovers turned out to be wired strangely and I'll be able to lose a bit of choc-block from inside the dash...
Hi mate, are the rear calipers and carriers still available? if so how much posted to Sheffield please.
p.s. do they come with the bolts?
jon.
Hi , Are the heating controls still availableand are they the later dial ones ?
Heater controls are gone I'm afraid.
---------- Post added at 11:38 PM ---------- Previous post was at 11:36 PM ----------
jon.
Hey Jon,
Both are still available:
Rear Brake Calipers 15.00 (pair)
Rear Brake Carriers 10.00 (pair)
And can probably rustle you up some bolts also, you want carrier to axle and caliper to carrier bolts..?
£25 for the brakes + £8 for postage due to weight.
Hi there,
Just wondering if you have a front engine mounting bracket? It's the one that connects the engine/gearbox to the front engine mount if that makes sense?
The part number is 357 199 273 if that helps :)
Cheers muchly,
Bruce.
Hi there,
Cheers muchly,
Bruce.
Hey Bruce,
Do indeed mate, still attached to the engine, seen here:
Just checked the VAGCAT armed with your part number I confirmed its still present.
£15 + £5 for postage.
Can drop you some payment details if happy with this...
Regards, Stu
Front page mega update.
Removed sold items (well most of them I think ;)
Anything you can't see, feel free to question as I think I'm missed a fair amount and have random spares from previous breakers also.
Hi, I'm after all the carpet retainers for a black carpet and the front doorcard retaining clips which hold the bottom of the doorcards. Please let me know if you have any?
Chris
Hi Will,
I have a selection of carpet retainers, do you have a picture of which type you are after and how many you want..?
Think I may have some doorcard retaining clips also...how many of these do you need..?
Regards, Stu
thanks for getting back to me. See below. whatever you have will help.
[ATTACH=CONFIG]59581[/ATTACH]
2 to 4
[ATTACH=CONFIG]59585[/ATTACH]
2
[ATTACH=CONFIG]59593[/ATTACH]
4 to 6
[ATTACH=CONFIG]59597[/ATTACH]
6
6 of the one below too.
Edited by Supercharged Will
Right that helps a lot.
I know I have a few of each but will have to check numbers and condition.
The 2nd one down however you may have to buy new as they are nie on impossible to remove without damaging them.
Be in touch.
Dug out the following this evening:
Tis what I have to offer...
