Jon_vr6 1 Posted April 28, 2012 Ive just installed my new Alpine headuit that comes with a usb connector on the back with a long wire. I want to install a port in the passenger side undertray so i can just connect an ipod, memory stick etc i want to make it look stock. I tried this method on vw vortex but im stuck as to how to attach the female usb connector to the undertray (as he has installed it into a switch blank) i think if i were to glue it in place then it would become unstuck in no time http://forums.vwvortex.com/showthread.php?3858584-Installed-Pioneer-Premier-P600UB-w-USB-port-in-my-B5-Passat Or do i get a computer usb plate cut it down and secure it to the undertray that way http://uk.ebid.net/for-sale/usb-pc-back-plate-internal-to-external-adaptor-cable-26390758.htm?from=googleshop_uk Any ideas, or even better anyone done something similar and could point me in the right direction Many thanks Jon Quote Share this post Link to post Share on other sites
seanl82 23 Posted April 28, 2012 The one one vortex looks a bit amateur, the metal tabs on the end have just been bent around the outer edge of the switch blank, but it kinda looks the only real way to do it. You may have to go the same route, but if you put some sort of cover over it, that would pass as OE I think, and you wouldn't be able to tell too much with the usb actually attached. Quote Share this post Link to post Share on other sites
science 0 Posted April 28, 2012 I just use an iPod lead to the centre cubby hole, was originally drivers side shelf for stealth. What would be the advantage of having a port over a lead? Quote Share this post Link to post Share on other sites
fla 9 Posted April 28, 2012 it would look tidier. I ahve two usb ports in mine - one is for the parrot handsfree and the other for the HU. Both are as leads sitting in the centre cubby hole but i'd like to have a cleaner solution too. Must be some way of linking up a computer USB port into a black dash point or elsewhere? Need some creative ideas input!! Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted April 28, 2012 Yeah it would look tidier fellas, im going for the computer usb route as the bolts on the front screw into and hold the usb port in place, i can then make a hole for the usb and two small screw holes paint the screws black and then its held in properly ---------- Post added at 8:14 PM ---------- Previous post was at 8:09 PM ---------- Something like this http://www.kenable.co.uk/images/USB2-PM-3M.jpg Quote Share this post Link to post Share on other sites
seanl82 23 Posted April 29, 2012 Yeah it would look tidier fellas, im going for the computer usb route as the bolts on the front screw into and hold the usb port in place, i can then make a hole for the usb and two small screw holes paint the screws black and then its held in properly ---------- Post added at 8:14 PM ---------- Previous post was at 8:09 PM ---------- Something like this http://www.kenable.co.uk/images/USB2-PM-3M.jpg That will look good. :thumbleft: Post a pic up when its all fitted. Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted April 29, 2012 Will do fella was cheap too http://www.kenable.co.uk/product_info.php?products_id=4323 Quote Share this post Link to post Share on other sites
krishen 2 Posted April 29, 2012 I've run my usb cable from the head unit to the glovebox (removing the glovebox light). This way there is no need to remove my ipod and no one can see it either. Quote Share this post Link to post Share on other sites
MikeVR6 0 Posted May 8, 2012 Mine's in the under-dash tray on the driver's side. Made a hole in the top of it and pushed the leads through. Ipod is hidden from sight down there. Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted May 8, 2012 Fitted my lead the other day works a treat Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted February 17, 2016 No pics Jon? :) To anyone who has done this please share your ideas as I'm currently installing a new stereo with usb inputs Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted February 17, 2016 Weird i thought i did i'll post it up soon mate. Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted February 17, 2016 Cheers pal :thumbleft: Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted February 18, 2016 [ATTACH]83223[/ATTACH][ATTACH]83224[/ATTACH] Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted February 18, 2016 Just made a small enough hole so the usb connector could be accessed and two holes either side to screw it into the undertray. Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted February 18, 2016 Not bad. Cheers. Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted February 18, 2016 Def the way forward. Love having usb in the bm Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted February 19, 2016 It could have been tidier but i wanted it out the way hidden almost Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted February 19, 2016 yeah im wanting stealth too :D head unit has 2 USB so ill use one for a memory stick with music on and the other for charging stuff Quote Share this post Link to post Share on other sites
delfinis38 1 Posted February 19, 2016 yeah im wanting stealth too :D head unit has 2 USB so ill use one for a memory stick with music on and the other for charging stuff Whats the new toy Vag hag. Quote Share this post Link to post Share on other sites
Philly-R6 2 Posted February 19, 2016 I like your idea. Did you consider an OEM-like connector? Something like: VW USB Block&Cable for RCD510 RCD310 USB AUX Switch Cable Harness RCD510 RCD300 Admittedly, the other end of these leads would require modification to accept the standard connectors from your head unit... Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted February 19, 2016 At the time i just wanted to have use of the ipod in the car so a quick fix was the best action. The above looks good though. Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted February 19, 2016 Whats the new toy Vag hag. Pioneer DEH-80PRS Hope its as good as the reviews :) Quote Share this post Link to post Share on other sites
