lilfuzzer
Breaking Rado aqua blue VR6 price for postage added and updated
Hi James unfortunately the spare ashtray I have does not have the backing sorry mate. But have the rest bud and as said could take to harewood house mate
Chris
That would be topper Chris. I'll swerve the light switch at the moment, as I'm convinced I can fix mine. Earmark the other bits I want though, as I'll put a list together in the next couple of days. See if I can put some more pound notes your way.
Thanks once again, James.
Couple of more parts for the box please Chris.
Little black door pin surround. Somehow I've lost one.
Foam blocks from the internal trim on the boot.
Here's the real test (half way down the page) :
http://the-corrado.net/showthread.php?46730-Carry-on-Campaign-Underside-a-go-go/page27
Needs to be in at least half decent shape. It sits against the tank and hopefully is better nick than mine.
I'll probably have a few more requests before the weeks out.
Thanks in advance
James
Also need a pair of front abs guides ( the bit that clips on to the suspension bolts and holds the abs wire).
Thanks in advance
James
Hi mate sure I have one of the pin surround i'll try and find it.
Foam blocks are there i'll check they are in good nick
Once the tank is off I'll check that part
The abs guide things are missing dude sorry.
I'll add to the box with the others chief
hi fella
i need a couple of bits in good condition
prices please posted for.
front ashtray
front rad cradle
passenger door,need some info on condition, ? rust damage filler? is the vehicle a 94-95?
front hubs incl bearing and spindle nsf ,osf?
nsf, osf /engine under trays, that screw to the front splitter, need to be damage free.
osf engine side cover that trim that covers the crankshaft pulley , also need to be in good nick, no damage cracks ect
cheers alex
Edited by volksworld13
Hi Alex
Ashtray has gone
rad cradle pics are on the front page
Also the door I replied to you before about it
hubs are available dont know the condition of bearings
the under trays are being held for now.
cheers
chris
Do you still have the calipers and carriers (front & rear)? If yes could you give me a posted price for both pairs.
Thanks.
Hi Alex Yes I do have them still ill go to the garage and fetch them back tomorrow night for weighing and let u know cheers
Chris
Dont suppose you have a working sunroof motor do you?
Hi mate sorry it went with the cassette
chris
hi, im after an o/s headlight, complete or just glass. do you still have one and how much would it be posted.
cheers Si.
Hi Si yep headlight still here I could do it for £50 posted mat complete headlight
cheers
chris
I need some mint a pillar trims in black, a working heater motor and a set of VR tank straps...
Can you help?
dont suppose you have a gearbox do you mate?? v5 box is a little too close ratio..
Hi mate yeah gearbox is here if you want to give it a go. was a none runner so didnt try what iot was like.
give me a shout if you like it buddy
---------- Post added at 9:39 AM ---------- Previous post was at 9:38 AM ----------
Can you help?
Hi Goldie I dont have the pillar trims as they have gone as have tank straps. Have heater blower but untested mate. your welcome to try it if you like?
Driver seat belt anchor/clip i.e. the bit the seatbelt clips into?
Hi mate yeah but they staying with the seats sorry
