hipcity
Black Rubber Trim
I'm interested in finding out if anyone has removed the rubber trim attached to the doors etc "external"
Does it look better removed?
How do you remove it :)
Thanks
hi i removed my trim it is on with tape it will come of ok by pulling it away the tape needs removed you will need thinners to do this the car looks better without the trim.
I prefer the trim removed. Makes the car look cleaner.
[ATTACH=CONFIG]67289[/ATTACH][ATTACH=CONFIG]67293[/ATTACH]
Edited by Wullie
hi i have the trim i removed it was on a 95 vr6 it that any good
I took mine off, chucked it, wished I hadn't, had to buy replacements. Now waiting to be refitted.
Pic of mine with trim removed.Benefit of keeping trim though is it gives some protection to panels in car parks etc
I removed mine but it left very sticky residue prob due to the fact it had been on 23 years just used a plastic filler card to get under the trim then pulled it off. it came off pretty easy I used a toffee wheel to get the sticky residue off then wiped it over with some panel wipe. I'll get a pic up to give you an idea of what it looks like.
I would be interested in trim you might remove, condition and price depending.
Sorry to jump in but neuon , if your still wanting that wheel when you get back i have a full set of good condition side strips if it helps you , you could probs save some money couriering it all at once , if not its ok
Matt
