daves16v 1 Posted July 13, 2012 (edited) Breaking - 1995 Classic Green VR6 OBD1 Most parts are available but as they are still on the car some might be damaged or not working after I’ve removed them so please shout up if there is anything you want. All prices are plus postage unless otherwise stated, I accept Paypal gift, bank transfer or cash on collection from NG10 5LR Notts. I’ll add to the list regularly so check back for updates. Parts are not sold until you say you want the item. Parts removed so far – Electric Recaro cloth interior, all seats and door cards - SOLD Lupo wipers (small spindle caps missing but are available from VAG) - SOLD Front grill (1 top tab broken) with Black VW badge - SOLD 4 pin MAF - Provisionally SOLD Inlet elbow - SOLD Front driver indicator (tiny chip) - SOLD Front pass indicator (tiny chip) - £10 Momo Team 300mm steering wheel with boss (some small marks but not worn) - SOLD Black parcel shelf - £35 collection only - SOLD Nearly new radiator - SOLD Headlight switch - SOLD 2x Front VR6 badge in Red - SOLD Plastic fan shield with Stainless screws - SOLD Front plastic HT lead holder - £5 ISV - SOLD Spare wheel with tyre - £10 collection only Jack and wheel brace - £10 Driver door handle - SOLD Pass door handle - SOLD Inlet manifold upper - SOLD Throttle body - SOLD Rear number plate plinth - £20 posted - SOLD Clock surround screw covers (1 tab broken on each) - SOLD Chrome rear VR6 badge - SOLD Chrome rear script badge, all tabs intact - SOLD Heater control bezel - SOLD Rear hatch sprung popper - SOLD Clock surround - SOLD Fog light switches - £12 posted Gear shift surround - SOLD Mcgard locking wheel nuts, radius seat to suit VR6 - SOLD VR6 auxiliary water pump - SOLD Water pipe engine to heater matrix - £13 posted Fully working sunroof assembly including roof panel in Classic Green - SOLD Black fusebox cover with both fixings - SOLD Handbrake - £10 posted Driver side lower shelf - £15 posted Spoiler raise switch - £10 posted Wings - SOLD Front bumper - SOLD Slam panel - SOLD Dash centre console - £offers as it's damaged (see photo and description of damage page 4) - SOLD Passenger interior shelf - SOLD Passenger footwell side cover - £15 posted ABS ECU - SOLD Interior A pillars in Black - SOLD Interior B pillars in Black - £10 collection only Interior C pillars + the rear centre trim in Black - £15 collection only Gear surround base - £15 posted Rear seat base and tailgate foam - SOLD Front splitter retaining strip blasted and powdercoated - SOLD Fans and fan mounting frame added, freshly blasted and powder coated. Fans mounted with Stainless flanged nuts - SOLD Indicator stalk - £10 posted MFA stalk - £10 posted Aux belt tensioner, will come with a new bearing - £20 posted Grey headlining - £20 collection only Rear parcel shelf supports with speakers - £25 posted for the pair Tailgate seal - SOLD Rear shock top covers - £10 posted for the pair Tailgate latch plastic surround complete with excellent fixing studs - SOLD Full set of 6 side rubbing strips, excellent condition - £40 posted Boot side carpet pieces in Black - £20 posted VR6 clocks showing 135k miles - SOLD Heater blower motor, all working - SOLD Interior sunroof trim, the piece that fits around the perimeter of the sunroof opening - SOLD Blasted and powder coated Black VR6 bonnet prop - SOLD Fan inlet mesh - SOLD Glove box in Black - SOLD Left and right front bumper guides - SOLD Power steering pump 135k miles - £25 posted Bonnet cable - SOLD Bonnet release handle - £10 posted Exhaust manifold shield - £13 posted Engine loom - £15 posted VR fusebox with fuses and relays - £20 posted Leather case for documents in Black - SOLD Fan control module - £15 posted Clutch slave cylinder - SOLD Throttle cable - £20 posted Boot carpet - SOLD Full carpet - £25 collection only Central locking controller - £15 posted Front seat belt assy LH or RH (includes the lower bar) - £20 posted Rear seat belt assy LH or RH - £15 posted Various pieces of heater ducting - prices on request Scuttle panel seal - £13 posted Lower windscreen trim seal - £13 posted Clutch master cylinder - SOLD Brake master cylinder and res - £20 posted Front headlining trim (runs across top of windscreen) in Grey - £15 collection only Fusebox mounting bracket - £12 posted Rear stub axles - £25 posted pair Rear brake pads, little wear - £10 posted Windscreen outer trim - SOLD Outer front triangular trim for doors - £8 each posted Door frame interior seal (runs around the door frame inside) - £12 each posted Front ABS loom, sensor to turret connector - £7 posted Electric window loom with integrated blower loom - £20 posted Sun visor driver in Grey - £10 posted Sun visor pass in Grey - SOLD Windscreen washer bottle and pump - £15 posted Tailgate top trim in Black - SOLD Left side footrest in Black - £8 posted Classic Green fuel flap, good condition, no rust - SOLD Exhaust centre hanger with rubbers - £15 posted Exhaust inner rear box hanger - £12 posted Exhaust heat shield, the one above the suitcase box - £10 collection only Exhaust heat shield, the smaller one at the rear of the petrol tank - £12 posted Fuel tank - £30 collection only Fuel tank filler shroud - £7 posted Tank pump cover - £7 posted Servo vacuum hose - £13 posted Inlet manifold lower - £15 posted Set of 6 injectors, condition unknown - £13 posted Plastic rocker cover - £20 posted Exhaust manifolds - £20 pair collection only Standard oil cooler - £15 posted Front engine mount - £15 posted Rear engine mount - £15 posted Oil filter housing with sensors - £20 posted Dipstick and tube - £15 posted Cable/hose heatshield, the one that wraps around the cables/hoses on the bulkhead above the exhaust manifolds - £5 posted Alternator/power steering pump mounting bracket - £15 posted Rear alloy engine mount bracket - £15 posted Door wiring rubber gaiter - £10 posted Edited April 1, 2013 by daves16v Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted July 13, 2012 Hi Dave, any pics of the grille? :) Quote Share this post Link to post Share on other sites
VR6 0 Posted July 13, 2012 More to the point ... Quote NOTE: You must be a Donator in order to create a new thread in this section Quote Share this post Link to post Share on other sites
daves16v 1 Posted July 13, 2012 Andy, will sort a pic out for you. VR6, I do donate on a regular basis, it might not be weekly or monthly but larger amounts every few months. Quote Share this post Link to post Share on other sites
VR6 0 Posted July 13, 2012 I don't doubt that Dave :) we can only go from your status as Andi looks after donations etc. I've no problem leaving the thread as is ... could you ask Andi if he can update your status to Donator? Quote Share this post Link to post Share on other sites
daves16v 1 Posted July 13, 2012 VR6 said: I don't doubt that Dave :) we can only go from your status as Andi looks after donations etc. I've no problem leaving the thread as is ... could you ask Andi if he can update your status to Donator? I've asked him along with another donation :thumbleft: Quote Share this post Link to post Share on other sites
robo22sri 10 Posted July 13, 2012 Dave can you get me a few pics of the steering wheel and boss please :) Quote Share this post Link to post Share on other sites
bristolbaron 11 Posted July 13, 2012 postage cost on the maf? Quote Share this post Link to post Share on other sites
Jim 2 Posted July 13, 2012 What's the bodywork like Dave..? E.g bonnet.. Quote Share this post Link to post Share on other sites
Storm Guy 0 Posted July 13, 2012 Hi Dave - Are both tow eyes there and if so are you willing to separate the lower front grille from bumper as an individual sale? Whats the condition of the rear number plate plinth too? Costs collected? - Thanks Quote Share this post Link to post Share on other sites
VWVW 1 Posted July 13, 2012 Hi do you have the dash ABS unit that has the part number 535 919 235 BA Quote Share this post Link to post Share on other sites
Wendy 0 Posted July 13, 2012 What about front and rear wing panels, both sides? Condition, pics and price please. ---------- Post added at 11:39 PM ---------- Previous post was at 11:37 PM ---------- Pics of wheels too please. Cheers Quote Share this post Link to post Share on other sites
g60knight 0 Posted July 14, 2012 i'll take the red vr6 grill badge please mate Quote Share this post Link to post Share on other sites
daves16v 1 Posted July 14, 2012 bristolbaron - £3 postage on the maf. Jim - the bodywork isn't good to be honest, the bonnet has a dent on the front and the usual stonechips and a bit of rust if I remember. The underside padding is a bit ropey too. It's not worth much at all, in fact if you want it collect for free. Storm Guy - If I remember one towing eye is damaged, yes you can have the lower grille if it's not damaged £10 collected. Price for plinth added to list, but I will check later today on condition. VWVW - the light wasn't working on the ABS unit but it might be something else that is causing this. I will check the part number later. Wendy - I'll take some pics of the front and rear wings, I know the rear pass arch has some extensive rust. I'll sort wheel pics also. g60knight - Badge is yours. Just a reminder, please keep questions in this thread to stay within the rules. Parts are not sold until you say you want the item. Thanks Dave Quote Share this post Link to post Share on other sites
g60knight 0 Posted July 14, 2012 Thanks buddy, i wll have the inlet manifold and throttle body aswell please. Quote Share this post Link to post Share on other sites
sake3 10 Posted July 14, 2012 vr6 badge :( I need one also screw covers for speedometer frame? Quote Share this post Link to post Share on other sites
GlosterOx 0 Posted July 14, 2012 Have you got the dash centre surround in good condition please? Ian. Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted July 14, 2012 Thanks for the pic Dave. Is it a genuine black VW badge or has it been sprayed? Are the top slats 'closed'? Quote Share this post Link to post Share on other sites
daves16v 1 Posted July 14, 2012 (edited) sake3 said: vr6 badge :( I need one also screw covers for speedometer frame? I remembered I had another Red VR6 badge - £18 posted. Screw covers now added to list. ---------- Post added at 7:57 PM ---------- Previous post was at 7:45 PM ---------- Storm Guy - one towing eye is damaged and the grille is also damaged. The rear plinth is ok apart from a small piece of plastic has chipped off at the bottom corner underneath. VWVW - the ABS light unit is working (wasn't connected) and is the correct part number - £20 posted. Had a good look at the wheels today, the rear two have almost no curbing, the driver side have a very small amount and the passenger front has the most curbing. The tyres are legal but only have about 1k miles left on them. Pics added. ---------- Post added at 7:59 PM ---------- Previous post was at 7:57 PM ---------- GlosterOx - the centre surround is broken in more than one place. CazzaVR - the badge looks like genuine Black and the slats are open. ---------- Post added at 8:10 PM ---------- Previous post was at 7:59 PM ---------- Wings and rear arch pics added. Edited July 14, 2012 by daves16v Quote Share this post Link to post Share on other sites
OllieVR6 0 Posted July 14, 2012 Hi Dave, I'm interested in the radiator but as mine is totally knackered I'd like to see it, any chance of some pictures? Is it VAG? Quote Share this post Link to post Share on other sites
daves16v 1 Posted July 14, 2012 ollievr6 said: Hi Dave, I'm interested in the radiator but as mine is totally knackered I'd like to see it, any chance of some pictures? Is it VAG? It's not VAG but it looks the same as the one I bought recently, yeah I'll get some pics but it may not be for a few days as I've only just got it off today and need to strip the fans off. Quote Share this post Link to post Share on other sites
VWVW 1 Posted July 14, 2012 daves16v said: I remembered I had another Red VR6 badge - £18 posted. Screw covers now added to list. ---------- Post added at 7:57 PM ---------- Previous post was at 7:45 PM ---------- Storm Guy - one towing eye is damaged and the grille is also damaged. The rear plinth is ok apart from a small piece of plastic has chipped off at the bottom corner underneath. VWVW - the ABS light unit is working (wasn't connected) and is the correct part number - £20 posted. Had a good look at the wheels today, the rear two have almost no curbing, the driver side have a very small amount and the passenger front has the most curbing. The tyres are legal but only have about 1k miles left on them. Pics added. ---------- Post added at 7:59 PM ---------- Previous post was at 7:57 PM ---------- GlosterOx - the centre surround is broken in more than one place. CazzaVR - the badge looks like genuine Black and the slats are open. ---------- Post added at 8:10 PM ---------- Previous post was at 7:59 PM ---------- Wings and rear arch pics added. Hi Dave. Thats great PM me your paypal details and I will send the money over. cheers VWVW Quote Share this post Link to post Share on other sites
Jim 2 Posted July 14, 2012 Cheers for letting me know about the bonnet Dave.. I was hoping it was minty so will pass :) Quote Share this post Link to post Share on other sites
daves16v 1 Posted July 14, 2012 Jim said: Cheers for letting me know about the bonnet Dave.. I was hoping it was minty so will pass :) I wouldn't be breaking if it were that good. There's rust on most panels except the roof and sunroof. ---------- Post added at 8:47 PM ---------- Previous post was at 8:35 PM ---------- More parts added. Quote Share this post Link to post Share on other sites
sake3 10 Posted July 15, 2012 (edited) can we make 20 posted for clock covers and vr6 badge? Edited July 15, 2012 by sake3 Quote Share this post Link to post Share on other sites
