ice_killer 10 Posted July 20, 2012 hey guys I went to my dealer today, to get me a sunroof repair kit But, apparently there are 2 different sunroofs. how can i tell witch 1 i have my C is from may 93 Quote Share this post Link to post Share on other sites
emu 0 Posted July 20, 2012 There is only one mechanism, the difference is only in the motor and plate with bolt pattern, early corrado has narrower bolt pattern and late, yours, has wider bolt pattern. All the linkage and parts inside are this same. I've taken few of them on parts to fix and never spotted any difference between them. Most of other vw sunroofs is using same parts as corrado apart linkages. Linkage mechanism are same in corrado and passat B3 with metal sunroof. Quote Share this post Link to post Share on other sites
ice_killer 10 Posted July 20, 2012 Ok, thank you. what i dont understand is that the dealer claims there are 2 different sun roofs. whit the plate whit bolt patern you mean, the frame? Quote Share this post Link to post Share on other sites
emu 0 Posted July 20, 2012 ice_killer said: whit the plate whit bolt patern you mean, the frame? no, there is small plastic plate in the middle of sunroof frame where you bolt on sunroof motor, you can take it off and swap it over to have wider or narrower bolt pattern, some of then have 2 patterns so you can swap early motor with new one. Sunroof frame is same in most of the vw cars, mk3, passat, seat ibiza, toledo, all of them and many more has same sunroof frame ---------- Post added at 10:21 PM ---------- Previous post was at 10:16 PM ---------- botom of the picture in the middle square black thing, that's what I'm taking about Quote Share this post Link to post Share on other sites
ice_killer 10 Posted July 20, 2012 aaah, nice thank you SO if i stick to the guides (dont know the correct english name for them), and cables im fine Quote Share this post Link to post Share on other sites
emu 0 Posted July 20, 2012 Yes, if your sunroof tilts but not slide in 99,9% one of the mechanism attached to cable has snapped, unfortunately mechanism and cable comes as a one piece. There is another part on the end of cable which is almost never broken. Quote Share this post Link to post Share on other sites
ice_killer 10 Posted July 21, 2012 OK, thank you. ill visit Monday the dealer again :). i already picked up the grease for the sunroof from the dealer. What an expensive stuff :-( Quote Share this post Link to post Share on other sites
Mike Edwards 0 Posted July 21, 2012 The cassette in which the mechanism fits differs between the early and late cars, with the result that you can use an early motor on a late cassette, but not the other way round. Additionally, if you start looking at glass roof cassettes, you'll see that the spacing pegs that hold the cassette away from the inside of the car's roof are longer. The mechanisms for Corrado roofs are all the same though, and they're the same as that used in all the other VW steel roofs from the same period (the glass roofs use a similar, but non-identical mechanism). If it tilts but doesn't slide, the casting on the end of one per both of the drive cables that run around the inside of the cassette and moves the mechanism has snapped. You will need a new cable or two, and probably a new mechanism (as play in the mechanism caused it to jam and that's what snapped the casting). The warning sign that you need to replace the mechanism is scratches on the passenger side of the roof panel. The cause is wear, generally made worse by poor lubrication. Yes, I do own an anorak. Why do you ask??? Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted October 26, 2012 emu said: some of then have 2 patterns so you can swap early motor with new one. If you swap in a late motor to an early frame to mate it up correctly you'll have to mod the motor casing like this!! ----> http://the-corrado.net/showthread.php?40512-Modding-late-sunroof-motor-to-fit-early-frame&highlight=early+late+sunroof+motor Quote Share this post Link to post Share on other sites
Classico 0 Posted September 16, 2023 i have a problem with my sunroof motor cover, in no way it want to fit. it looks like the motor is to thick/high ? i have the 6 pin motor in a 1994 are there more variations of this 6 pin motor? Quote Share this post Link to post Share on other sites
