daves16v 1 Posted November 5, 2012 Can someone explain how to remove the outer rubbing seal strip on top of the door panel. I have the door off the car so hopefully that might make it easier. Thanks. Quote Share this post Link to post Share on other sites
Riley 0 Posted November 5, 2012 The 'Door dent stopper' Dave? lol. Or window seal? For the door trim rubber, heat gun and gentle prying. Obviously paint removal may occur! Quote Share this post Link to post Share on other sites
daves16v 1 Posted November 5, 2012 The 'Door dent stopper' Dave? lol. Or window seal? For the door trim rubber, heat gun and gentle prying. Obviously paint removal may occur! Window seal. Quote Share this post Link to post Share on other sites
Riley 0 Posted November 5, 2012 Ah...I once took one off to paint the door on my old Valver. I'm pretty sure it just pulled up from the handle end of the door, although I remember it was very easy to bend. Just easing it off as much as you can really from what I remember. Can see it removed in this pic. And refitted here (End was already wobbly before it was removed) Quote Share this post Link to post Share on other sites
daves16v 1 Posted November 6, 2012 Thanks Neil, will give it a go. Quote Share this post Link to post Share on other sites
Stonejag 10 Posted November 6, 2012 Yes, they just pull straight up (they're a U-shape clipped over the door edge). If you can support it in the middle as you go you have a better chance of getting it out in one piece, when I removed one of mine pulling at just the end made it crack in the middle :( You might also consider giving it some silicone spray or WD40 to try and feed the rubber - keep it moist and it might be slightly more robust. Then again, after twenty years they may as well be made of cheese! Stone Quote Share this post Link to post Share on other sites
robrado974 1 Posted November 6, 2012 And very expensive to replace if you have to ! Quote Share this post Link to post Share on other sites
VW_OwneR_85 2 Posted November 7, 2012 yea avoid bending it at all costs, they have a metal strip down the inside and once its bent its blady hard to get straight, might help if you had the window out and pushed the seal in the middle up and inwards towards the car interior if ya get me?, that might help free it from the sealing lip in the window channel. Quote Share this post Link to post Share on other sites
daves16v 1 Posted November 7, 2012 It's coming off my breaker so if it bends then I'm just out of pocket a little. Thanks for suggestions. Quote Share this post Link to post Share on other sites
