Rocket Ron 1 Posted February 21, 2013 Has anyone fitted day time running Led's to their car. Fancy doing it but if anyone already has and it incorprates the existing lighting system ie goes off when you switch main lights of whould like to hear from you. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted February 21, 2013 I just use my foglights with headlights on side light setting. Seems to work and bothers certain drivers, which i like. Quote Share this post Link to post Share on other sites
VWVW 1 Posted February 21, 2013 In my opinion daylight running LED on modern cars are far brighter than the corrado fog lights. Quote Share this post Link to post Share on other sites
Wullie 1 Posted February 21, 2013 I just use my foglights with headlights on side light setting. Seems to work and bothers certain drivers, which i like. Might just bother the plods as well. They are fog lights and there are rules for their use. Quote Share this post Link to post Share on other sites
timmaaah 0 Posted February 21, 2013 Don't do it - it will look utterly **** and everyone will think you are a penis. As for wiring up/using fog lights as DRL :nono: :rolleyes: Quote Share this post Link to post Share on other sites
Portent 0 Posted February 21, 2013 Just turn the sidelights on? Quote Share this post Link to post Share on other sites
tony_ack 0 Posted February 21, 2013 Just turn the sidelights on? Exactly what I thought when I saw the thread title... Quote Share this post Link to post Share on other sites
Rocket Ron 1 Posted February 21, 2013 I only asked the question core was not expecting that sort of response !!! Quote Share this post Link to post Share on other sites
tony_ack 0 Posted February 21, 2013 Okay, well I haven't done it, but you'd probably need to power them off the ign live, and then have a relay in line which crosses over the lighting circuit, and opens the DRL circuit when current passes through the lighting circuit. When you switch the lights on, the relay should then switch off the DRLs. Make sure you put a fuse in line too. Quote Share this post Link to post Share on other sites
Rocket Ron 1 Posted February 12, 2014 I've fitted a set of ring extra bright DRL complete with relay the come on when ignition is on and when side light are switched on they go of iaw regs. I've integrated them into the main light fitting so no cutting involved. Quote Share this post Link to post Share on other sites
davidwort 0 Posted February 12, 2014 The Corrado has DRLs, it's called dim dip and happens when you turn the ignition on and sidelights on, the main headlight dip beam filament is fed through the yellow dim-dip resistor, which has to be unplugged if you use aftermarket relays to bypass the original lighting loom. Dim dip is bright enough to create a beam pattern but not so bright as to pee other road users off, as in the case of overly bright LED DRLs. Quote Share this post Link to post Share on other sites
Brunty 10 Posted February 12, 2014 I've fitted a set of ring extra bright DRL complete with relay the come on when ignition is on and when side light are switched on they go of iaw regs. I've integrated them into the main light fitting so no cutting involved. Got any pics? I'm not sure that the modern DRL look would suit the Corrado, but happy to be proved wrong as these days they could be considered a safety feature. Quote Share this post Link to post Share on other sites
add1 10 Posted February 12, 2014 The Corrado has DRLs, it's called dim dip and happens when you turn the ignition on and sidelights on, the main headlight dip beam filament is fed through the yellow dim-dip resistor, which has to be unplugged if you use aftermarket relays to bypass the original lighting loom. Dim dip is bright enough to create a beam pattern but not so bright as to pee other road users off, as in the case of overly bright LED DRLs. Ive recently picked up my 1st corrado over xmas and have noticed the front sidelights are on dimmed all the time, thought maybe its a dodgy lightswitch but the rear lights aren't on???? Quote Share this post Link to post Share on other sites
davidwort 0 Posted February 12, 2014 Ive recently picked up my 1st corrado over xmas and have noticed the front sidelights are on dimmed all the time, thought maybe its a dodgy lightswitch but the rear lights aren't on???? That's not normal, I'd investigate a bit more... Quote Share this post Link to post Share on other sites
dragon 0 Posted February 13, 2014 Ive recently picked up my 1st corrado over xmas and have noticed the front sidelights are on dimmed all the time, thought maybe its a dodgy lightswitch but the rear lights aren't on???? My VR6 was like this when I got it , I thought it was strange till found out my headlight switch was playing up/broken . But you never know exactly what previous owners have done to your car as I have found out with this one more than once Quote Share this post Link to post Share on other sites
add1 10 Posted February 13, 2014 yeah my headlight switch doesn't turn off the lights sometimes so guess that maybe the problem, thanks! Quote Share this post Link to post Share on other sites
Rocket Ron 1 Posted June 10, 2014 Some pics soon and just had MOT and passed so they do not interfer with beam. Quote Share this post Link to post Share on other sites
Rocket Ron 1 Posted October 3, 2014 How do you up load photo on this site ????? Quote Share this post Link to post Share on other sites
Brunty 10 Posted October 3, 2014 How do you up load photo on this site ????? I think it's easiest to upload the photo to somewhere like photobucket (I use my Google+ account though). Copy the photo url and then click the insert photo button above the text box, select remote host and paste the url in. Quote Share this post Link to post Share on other sites
Jim 2 Posted October 3, 2014 Attachments on here work just fine - you just need to resize the pictures down to a sensible size first :) Quote Share this post Link to post Share on other sites
davidwort 0 Posted October 3, 2014 Attachments on here work just fine - you just need to resize the pictures down to a sensible size first :) yep, the upload just does nothing if the image is too large, not great. to upload you need to 'Go Advanced' when writing a reply and then 'manage attachments' Quote Share this post Link to post Share on other sites
Rocket Ron 1 Posted October 3, 2014 (edited) This is it linked with google+ account I know not to everyones taste no cutting and goes through MOT. Also has an affect when you approach from behind. https://lh4.googleusercontent.com/-GrgoOhbGhpA/VCXTpizMCXI/AAAAAAAAAbY/RHFQV6ZykBo/w831-h623-no/IMG_2596.JPG Edited October 3, 2014 by Rocket Ron Quote Share this post Link to post Share on other sites
KipVR 1 Posted December 30, 2014 What have you put in your main beam reflector? Quote Share this post Link to post Share on other sites
Rocket Ron 1 Posted January 3, 2015 Nothing I just mounted them inside using brackets provided with kit. I did manufacture a small shield to protect wiring from heat of main beam otherwise was simple enough. Quote Share this post Link to post Share on other sites
