timmaaah 0 Posted February 25, 2013 I need an ignition switched power supply, but one that doesn't then briefly turn off when the engine is cranked. The glovebox light feed seems to flick off when the engine cranks, as does the power supply to the radio. Any idea as to where I can get a stable, ignition switched live feed from? One that specifically doesn't dip/flick off when the car starts? I want to hard wire in my satnav, but it turns off when the car is started - it goes like this: Ignition on - satnav turns on - start car (power supply dips) satnav turns off :/ Many thanks :) Quote Share this post Link to post Share on other sites
tony_ack 0 Posted February 25, 2013 Does the sat nav not run off a battery? I think all interior electrics go through the load relief relay, which reduces load on all non-essential systems when the car is started. The only ones I can think of that won't are anything to do with the engine and starter, and perhaps the side lights? Quote Share this post Link to post Share on other sites
timmaaah 0 Posted February 25, 2013 tony_ack said: Does the sat nav not run off a battery? I think all interior electrics go through the load relief relay, which reduces load on all non-essential systems when the car is started. The only ones I can think of that won't are anything to do with the engine and starter, and perhaps the side lights? Yes - it has a battery, but it auto turns on and off with the power supply, but because there's that dip, it turns off when I start the car, meaning I have to manually turn it back on :/ Quote Share this post Link to post Share on other sites
easypops 8 Posted February 25, 2013 Do you have really short arms? :lol: Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted February 25, 2013 Do headlights stay on when ignition is turned. But go dimmer. Quote Share this post Link to post Share on other sites
vw rule 19 Posted February 26, 2013 You've normally got four positions on the ignition switch, 0) ignition switched off (everything is off now (accept for the radio and ECU plus clock memory) 1) is the auxiliary (powers the radio with ignition off) 2) is ignition switched on (everything has power now) 3) is the cranking position (supplies power to the starter so to start vehicle) Lights on the Corrado or any vehicle may flicker if there on as the starter motor is quite a large drain on the electrical system i.e battery, same for the radio it may flick off for a second when cranking over the engine until it starts up, then the ignition switch goes back to position 2 What I'm saying is you should be able to get power from the auxiliary wire from the ignition switch, then you should be all sorted. Or you could get power directly from the fuse box i.e the main battery feed. You say the satnav turns off when you crank the engine, why not just start the car up and then turn on your satnav, job done. Hope this helps Si :thumbleft: Quote Share this post Link to post Share on other sites
Riley 0 Posted February 26, 2013 I think he just wants the satnav to come on with ignition/engine running and stay on, rather than having to physically turn it on. :thumb: Fag lighter feed? Quote Share this post Link to post Share on other sites
timmaaah 0 Posted February 26, 2013 Yeah - I'm a lazy sod!! I really want the satnav to turn on and off by itself (it's such a pain to do it manually :D) The fag lighter on mine is permanently live - is that normal? Cheers Si - I'll get my multimeter out and have a play - thanks :) Quote Share this post Link to post Share on other sites
Supercharged 2 Posted February 26, 2013 I think one of the 1 pin aux sockets on the top of the fusebox is switched - not sure if it goes via the X relief relay though Quote Share this post Link to post Share on other sites
davidwort 0 Posted February 26, 2013 timmaaah said: The fag lighter on mine is permanently live - is that normal? yeah, how else would your passenger light up a smoke while you're at the petrol station? Quote Share this post Link to post Share on other sites
timmaaah 0 Posted February 28, 2013 Sorted - the voltage drop on the glovebox light is minimal during cranking, so I've taken a feed from that :) - not sure why it didn't work before :/ Quote Share this post Link to post Share on other sites
