chaos3oe
Breaking 1993 Bordeaux Red VR6, FULL LIST OF PARTS LEFT ADDED
This is the final list of parts i have left with prices (postage extra). Open to offers on all Parts if any pictures are required please let me know and i will post them up. All parts are plus postage, or can be collected from Barrow-in-Furness.
I will accept bank transfer (prefered), paypal gift or cash on collection for payment.
Crack Pipe - Perfect 021 121 085 E £5.00
Front Lead Holder - V Good 021 133 917 £7.50
Interior Grab Handle - V good incl fixings and screws £5.00
Fuel Flap Assembly - Rust free but Scratched £5.00
Coolant Tank Trim 1H0 121 422 £2.00
Pass Door Mirror - new glass needed £20.00
Adj Steering Column Lever - With Screw £5.00
4 off Seat Belt Shoulder Bracket Trim165 857 719 £2.00 ea
Fuel Line Heat Shield Velcro Fabric Cover £5.00
Bulkhead Heat Shield Velcro Fabric Cover £5.00
Pass Side Front wing Rubbing Strip - Light Scuffing £5.00
Pass Side Rear qtr Rubbing Strip - Light Scuffing £5.00
Glovebox - Lid Mint 1/2" Hole in Back Corner £15.00
Mid Scuttle Trim - Good £10.00
RH Scuttle Trim - Cracked Trim Edge £5.00
Windscreen Surround Trim - Presentable £5.00
Dash Top Grill - Need Painting 535 857 463 £5.00
Dash Top Grill - Need Painting 535 857 464 £5.00
Inner Sunroof Surround Trim - Needs Cleaning £10.00
Drivers Sun Visor - Mint £10.00
Passenger Sun Visors – Mint £10.00
Sun Roof Switch and Panel - V Good £15.00
O/S Dash Blower Vent - V Good 536 819 706 A £10.00
N/S Dash Blower Vent - V Good 536 819 705 A £10.00
Fuel Flap C/L Actuator 357 862 153 A £5.00
Dash Speaker Grill - Good 536 857 210 £5.00
Bee Sting Aerial - Good Offers
C/L Pump 1H0 962 257 £15.00
C/L Pump Holder + Bracket Strap £10.00
Rear View Mirror - Good £15.00
H/Brake Lever 191 711 307 E £10.00
H/Brake Cable Balance Piece £2.50
Dash Centre Grill cover (speaker finish) 536 858 061 £5.00
Dash Side Air Vent 536 819 751 A £5.00
Dash Side Air Vent 536 819 752 A £5.00
Brake Fluid Bottle Offers
Rear Strut Top Cover 191 512 135 £2.50
Corrado Front Flexi - New £5.00
Fuel Tank Cover Plate £5.00
Rear Ash Tray 321 857 961 £10.00
Rear Beam ABS Wire Holder 535 971 852 Offers
Dip Stick and Tube Offers
Front Seat Belt Bar 535 857 775 £5.00
Front Seat Belt Bar 535 857 776 £5.00
Rear Beam ABS Wire Holder 535 971 851 Offers
Lower Gearbox Cover Plate £10.00
Indicator Stork £10.00
MFA Stork £10.00
ADJ Steering Column Including Lock Housing £25.00
Rear Wiper Motor £15.00
Gear Shifter Cables £10.00
Tailgate Seal - Good £15.00
Power Steering Hose - Good 535 422 887 Offers
Coolant Hose - Good 535 121 063 A £10.00
Lower screen Scuttle Seal - OK £5.00
Fog Light Switch £5.00
Door Wiring Boot 535 971 916 £2.50
Coolant Tank 021 121 407 Offers
Dash Ash Tray £15.00
Under Dash Trim Left £15.00
Under Dash Trim Right £15.00
Black Parcel Shelf £30.00
Boot carpet set for space saver wheel - Good £40.00
Under Seat Foam 535 863 857 £5.00
Under Seat Foam 535 863 858 £5.00
MK1 Golf Front Bump Stops and Covers (New) £10.00
MK3 Golf/Corrado VR6 Rear Bump Stops and Covers (New) £10.00
LHD Split Screen Steering Idler Arm £20.00
Recaro Seat Back Foam Bolster Surround From Cosworth £25.00
VR6 Airbox - Internal Cone Removed £15.00
Rear Engine Mount Heat Shield £5.00
Fuel Tank to Body Seal 535 201 253 £5.00
Brake Servo £20.00
Exhaust Heat Shield £5.00
Starter Motor £25.00
Water Pump £10.00
O/S Door Card Top Trim £10.00
N/S Inner Scraper Seal £10.00
O/S Inner Scraper Seal £10.00
Rear Wiper Arm £5.00
Rear Beam New Bushes with Zero Miles £60.00
Rear Spolier Blade Panel Good Paint £20.00
Spolier Motor and Mech £35.00
Tailgate Lock £5.00
Boot Struts (Pair) £15.00
Int/ext Mirror Trim Triangles £5.00
Seat Belt Height Adjuster Mechanism £10.00
Front Wiper Motor/Mech £25.00
Fan Mesh Cover £10.00
PAS Bottle, Pipes and Bracket Offers
Steering UJ Shaft £15.00
Steering UJ Boot £10.00
Steering Rack £40.00
Front Subframe £40.00
Front Engine Support £15.00
Wishbone With Good Bushes and Ball Joint £15.00
Anti Roll Bar Offers
Standard Suspension Dampers, Bump Stops and Front Top Mounts 18 Months Old Offers
Gearbox £75.00
Arch Liner £10.00
Arch Liner £10.00
Bonnet Stay Offers
Good Flywheel £20.00
Left Front Wheel Hub Recent SKF Bearing £25.00
Right Front Wheel Hub Recent SKF Bearing £25.00
Edited by chaos3oe
This is how you do a breaking thread - thankyou!
Will take the blower fan please! :) Could you PM me payment information please mate?
VR6 DOHC Engine cover £5 and red front VR6 badge £5 please, posted to Glasgow :)
Oh and the oil filter £3 also :)
Edited by easypops
Hi, I'll take the intake elbow and pipes please as long as there's no cracks.
How much posted?
Cheers
Gus
Are any of the body pannels available?
what condition is it in?
Ie straight / rusted / blemishes / laquer peel?
And by bordeaux is it colour code lc3y?
Thanks. Paul
Paint code is LC3Y. the car does have all panels but has its fair share of blemishes so will be easier if you let me know what panels you are looking for and i can give you a detailed description and pictures.
I'll take the new spring for brake regulator -pm sent.
Sorry I've discovered the regulator and spring are different on the 16v so this is no use to me: still available!
Edited by bmwcompact
  BILLCOR said:
I'm interested in the rear beam, condition and price please posted to KY16 8RZ
The ream beam has been cleaned up and painted and has brand new bushes installed, I was intending the car to go back on the road before I found the rot. It is currently re fitted to the car so I can move it while stripping it. The plan is to get the engine out next week and then all the running gear can come off, so this should be available in the next 2 weeks. I want £100 plus post for it, which as a guess should be somewhere between £20-£40, basically what it costs me through collect my parcel(need to weigh it). Picture below, if you want it i'll stick your name on it.
---------- Post added at 12:38 PM ---------- Previous post was at 10:46 AM ----------
  Southie said:
What condition is the dash center console ?
Southie,
Depends what you are after, if you want a mint one, this probably isn't for you, Once fitted I would describe this as presentable. It has a crack on the radio surround, and one part of the heater control mounting is broken, pic below.
---------- Post added at 12:41 PM ---------- Previous post was at 12:38 PM ----------
  Goldie said:
Can i get a close up picture of the heater control surround panel please?
Heater control panel pictures.
What has it been painted with and what bushes did you use
The beam has been wire brushed and a coat of rust converter on any scaly bits and then painted in black hammerite. This was just to protect it not a top class finish.
The bushes are from a local factor, firstline brand cost £46, I have the new nuts and bolts that came with them these will go with the beam.
cheers
Hi mate how much for the petrol cap i left mine at the garage last week only noticed this morning when i went to fill up :bad-words: posted to sunny kilmarnock please.
£5 and i'll send it first class in the morning so you'll hopefully get it Sat?
Pm me you detail's matey :thumbleft:
  Critical_Mass said:
Hi mate,
How much for both front wings and bonnet. Assuming there's no rust.
Unfortunately the front end panels are not really good enough to be fitted without a respray and a couple of small repairs. The bonnet has no rust but needs a respray and a small dent sorting. The drivers wing has a small amount of rust on the rear of the lip, and the passenger wing has a rust bubble by the side repeater. If you want pictures I can take you some tomorrow.
---------- Post added at 8:25 PM ---------- Previous post was at 8:24 PM ----------
Sending to you via PM. The handbrake handle has gone.
  krishen said:
Hi,
Do you have a leather handbrake handle? If so what condition is it?
Also can you email me a close up of the passenger side fog please krishensoni@hotmail.com
Thanks
Edited by chaos3oe
cheers
Thanks for the reply, I'll leave this just now and see if I can pick one up a bit more local to me, I may be back :thumbleft:
Ideally looking for a mint tailgate that i can bolt straight on, no rust / laquer peel - Mint
Ok, ill take the heater surround. Im assuming the oil filetr housing is free from damage, is it the upper and lower parts? IF so ill take that as well please..
PM me your details...
