MattPc
VR6 Parts, updated 31.3.13
I have a few VR6 parts as I am clearing out, whist also converting to OBD2.
All parts are in good working order unless stated. Items are + postage or collection from Braintree.
1, VR6 OBD1 over bored throttle body, welded underneath to add wall thickness. It has a direct acting butterfly rather than a ratio butterfly from factory, Sold
2, VR6 Catalyst, has a weld on the underside, mating surfaces cleaned, in good working condition, Sold
3, VR6 airbox inlet plate, the bit that sits behind the headlight, £5
4, Set of coil pack HT leads in black, £20
5, Bosch starter motor, Sold
6, VR6 manifold heat shield, £10
7, Fuel rail, £5
8, Dual tone horns, rusty, Sold
9, 288mm Fabia VRS front calipers, carriers, pads, hoses & discs, sold
10, Jetex stainless steel exhaust cat back system, 3 years old, the underside of the system is nice and shiny, top of the back box still has some of the protective cover on, the dark bits in the picture. it comes with an adapter to mount to the standard CAT. includes three new exhaust clamps. Sold
11, Master cylinder with reservoir, £20
12, Brake servo with position sensor, £45
13, Manual pedal box, £20
14, 2 sets of standard VR6 injectors, £10 per set
15, Thermostat housing & thermostat, £5
16, Power steering pump & reservoir, £30
17, Alternator/ AC compressor/ PS pump bracket, £5
18, Inlet air pipe to TB, £5
19, 15" Space saver wheel, £10
20, Idle stabilization valve, £20
21, Valeo Clutch & clutch plate, covered 35k on a standard engine, £20
22, 02A CCM gearbox, 107k miles on a standard engine, £50
23, New front brake dust shields, Sold
24, New rear brake dust shields, Sold
25, 3 bar fuel pressure regulator, £10
26, 2x Auxiliary belt tensioner, £15 each
27, 4 bar fuel pressure regulator, £10
28, 2x Coolant header tank with cap, £10 each
29, OBD1 throttle body, £15
30, Water pump pulley, £3
31, Steering colunm UJ bulkhead gaiter, £5
32, Standard 12V VR6 flywheel, ideal for lightening or replacement, £10
33, VR6 fuel lines, tank to fuel rail, with filter carrier & filter, £10
34, Charcoal canister valve with pipe to TB, £5
35, Radiator fan controller module, £3
36, Rear engine mount aluminium exhaust heat covers, £10
37, Standard VR6 cams, both 2.9 & 2.8 sets available, £10
I'll add some more parts later on.
Any questions please ask
Regards
Matt
Edited by MattPc
RadoVirgin, PM replied to regarding payment.
science, I will be down in Basildon on Thursday 28th if that helps with collection, if not a 24hr courier would be £10.50
Matt
Matt
Thanks Matt, could you courier them please. Just let me know payment details, cheers.
Neil
RadoVirgin, TB posted this afternoon,
Some more parts added to the first post.
Matt
Edited by MattPc
pastmann, The brakes will be collected on Tuesday due to the bank holiday.
I have also added some more parts to the list.
Matt
Hi will the exhaust fit a G60? Or do you have part number for it so I can check myself.
Also could offer postage if it does fit.
Ben, I will measure the cams I have as I am sure that I have both 2.8 & 2.9 spare sets.
sankysvr6, The kit code is 26-H7TR system. I have checked on the Jetex website and that also confirms that the systems fits both the VR6 & G60, and I can box it up and send via a courier.
Matt
hi
have you got the top part of the standard air filter box for sale
stephen
Sorry for the late replies everyone.
Hi mate
Are the cams from a 2.9?
Ben
I have checked and I have both th 2.9 and 2.8 spec cams, which ones are you after?
New front&rear brake dust shields
Will they fit late type vr6?
If yes will you let it go £50 delivered to NR32?
Yes they will fit the late VR6, I have somebody else interested in the front dust shields, I will await a reply on weather they take them.
hi
stephen
Funnely enough I do have a spare top half of the VR6 airbox, £10 + £3.50 postage sound ok.
Matt
Hi mate cheers. I'm going to leave them for now as plans have changed!
Cheers anyway
Appreciate it
Ben
Matt
thanks for the reply and will have the top half of the air box.
how's best to pay you?
Stephen
