Scott
Just Installed new speakers in VR6.....Sounds pants!!!!
Thats a fair point Kev....
I might just mount it on back of seats and makes sure all wiring is hidden....
I ALWAYS use blankets etc to protect my carpets / seats anyway when using corrado to transport dogs (although the majority of the time they go in Pug!) so I could cover the amp off....
That's your answer then dude..... just transport the dogs in the Pug only :lol:
Like I said 95% of the time this is the case but its not always possible and usually involves me cleaning the windows after to remove the nose marks!!! :lol:
My sub and amp install going in tommorrow 8)
Good man. Life is made easier putting the amps on the seat because behind the carpet and wood it's metal sheet, so it's not going anywhere :wink:
Its just made me realise how small the boot is!!!
My box wont fit unless I tip it on its back!!! :mad:
LOL
I also have a much smaller box but my mate says the bigger box is tuned for the sub.... the smaller one isnt so doesnt sound as good....
The bigger box sounds MUCH better than the small one.... takes up about 1/3rd of my boot though... :D
The difference the sub alone has made is un real.... my pioneer head unit has the facility to adjust the sub from the head unit via digital cross over, etc.
So I have set the sounds to send everything below 125hz to the Sub and the rest to the other speakers.... the difference is amazing... you can now hear the speakers in the dash / doors going TSSSSSCCCCHHHHH and the sub dropping and rising bass notes..... :lol:
LOVE IT!!!
Cant wait to stick the focals in now :shock:
Only problem I can see when I put the focals in is that I wont be able to use the head unit to adjust the sub levels as it will affect the focals and the sub..... :?
I will have to adjust it on the amp I assume....
I have a cross over on the amp on each PAIR of channels.....
Which have adjustments that are:
HPF
FLAT
LPF
I assume the channels bridged would run LPF?
and the Focals would run HPF?
Scott
HPF
FLAT
LPF
Scott
Sounds good to me.... 8)
Hey all,
Dont know if anyone metioned this before, but on my '93 corrado the negitive wires were all brown w/ some different color stripe. And the positives for the speaker wires were all other colors w/ some strip... ie blue w/ red. Hope this helps with the factory speaker wire set up
On a different note
I have infinity 6.1 perfect speakers going in the front, in audioscape door pods(soon as i get em ) .
I wanna run a sub and power em both from one amp if possible. Any idea's on a good amp for this? Or should i consider 2 amps, one for the sub and one for the component speakers? Been a while since i put a system together.. so any advise would be helpful :)
