Johnny H 0 Posted May 5, 2013 Hi guys. I've brought these of someone I know who said they where mk4 golf rears. So when the car was the garage I asked if they could fit them but they said said they wasn't the right ones. Could someone have a look and tell me if they are or not please. Thanks Johnny [ATTACH]73910[/ATTACH] [ATTACH]73911[/ATTACH] [ATTACH]73912[/ATTACH] Quote Share this post Link to post Share on other sites
dumptyboy 0 Posted May 5, 2013 Yes they are mk4. :) Quote Share this post Link to post Share on other sites
Johnny H 0 Posted May 5, 2013 Then why couldn't they fit them with the new lines I brought. They said the lines were to short to fit these callipers? Quote Share this post Link to post Share on other sites
swampy 0 Posted May 5, 2013 They probably looked at the lines attached and the lines you supplied and as they are different length said that. But the way the fit. Is different, as you have a short flexi, then a bracket that holds a rigid metal pioe Quote Share this post Link to post Share on other sites
dumptyboy 0 Posted May 5, 2013 You need mk4 conversion lines to fit them. They need a banjo bolt fitment. Google mk4 brake conversion. Hope that helps. Quote Share this post Link to post Share on other sites
delfinis38 1 Posted May 5, 2013 (edited) Also they won't fit with the Mk4 carriers which the calipers are attached to in the picture as they are a different pitch. you need to use the corrado carriers. make sure the calipers have a 38mm piston. not 32mm (polo) or 41mm which is golf estate Edited May 5, 2013 by delfinis38 Quote Share this post Link to post Share on other sites
Johnny H 0 Posted May 5, 2013 You need mk4 conversion lines to fit them. They need a banjo bolt fitment. Google mk4 brake conversion. Hope that helps. Hi mate. I've got the right lines with the banjo bolts to do the conversion. Johnny ---------- Post added at 8:19 PM ---------- Previous post was at 8:17 PM ---------- Also they won't fit with the Mk4 carriers which the calipers are attached to in the picture as they are a different pitch. you need to use the corrado carriers. make sure the calipers have a 38mm piston. not 32mm (polo) or 41mm which is golf estate Hi mate. I will have to check tomorrow. Thanks mate. Johnny ---------- Post added at 8:20 PM ---------- Previous post was at 8:19 PM ---------- They probably looked at the lines attached and the lines you supplied and as they are different length said that. But the way the fit. Is different, as you have a short flexi, then a bracket that holds a rigid metal pioe Hay swampy So they should be upside down really then? Johnny Quote Share this post Link to post Share on other sites
swampy 0 Posted May 5, 2013 No I'm sure they fit the right way up Hose and bleed at top Cable at bottom Have a look in volksdevil build thread he has the same lines and shows them all fitted up Quote Share this post Link to post Share on other sites
delfinis38 1 Posted May 5, 2013 some good picture on page five of this thread.... http://the-corrado.net/showthread.php?40893-Mk4-Golf-Rear-Calipers-Upgrade-Re-Parts/page5 Quote Share this post Link to post Share on other sites
GrahamU 5 Posted May 5, 2013 To be sure, whats the part number on them Quote Share this post Link to post Share on other sites
Dox 22 Posted May 5, 2013 MK4s don't have the external helper springs. These were removed from my own mk4 and sold to Fla ---------- Post added at 9:55 PM ---------- Previous post was at 9:52 PM ---------- If they are MK4 (and I doubt it) you need to fit them with the original corrado carriers as the mk4 carriers have different hole spacing where it bolts to the axle Quote Share this post Link to post Share on other sites
GrahamU 5 Posted May 5, 2013 Just had a look at the collection I have in the garage and they look like b5 passat rears Quote Share this post Link to post Share on other sites
Johnny H 0 Posted May 5, 2013 Just had a look at the collection I have in the garage and they look like b5 passat rears I'm sure that's what one of the guys from the garage said. Thanks guys. Anyone have any MK4 callipers that they want to sell?? :lol: Quote Share this post Link to post Share on other sites
delfinis38 1 Posted May 6, 2013 I'm sure that's what one of the guys from the garage said. Thanks guys. Anyone have any MK4 callipers that they want to sell?? :lol: I missed the springs nI the picture I agree that they are not the correct Quote Share this post Link to post Share on other sites
