Rams 0 Posted May 8, 2013 Polished rocker cover with appropriate gasket, when I had it fitted it was gleaming so just needs so wet and dry/autosol to return the shine. £50 plus delivery Miltek sports de cat pipe with Lamba which I can't get out. £25 Set of calliper carriers, they have been blasted and wet painted professionally in black, had them done and realised they didn't fit my car. Part number 5612/41211 and 5612/4 2191. If anyone knows what they would fit I'd appreciate it? £45 OBD1 inlet pipe in perfect order £15 OBD1 late ecu in perfect working order £45 Audi TT 4 inch MAF and suitable AST silicone pipe adaptor £40 OBD1 MAF complete with sensor, again, perfect working order £30 Coolant Thermostat housing £10 More parts to be added. The above are all without postage, so postage costs would be additional. Located in Bournemouth for those who wish to collect. Cheers Quote Share this post Link to post Share on other sites
Rams 0 Posted May 8, 2013 Continuing Vr6 fuel pump sender and pump, runs quietly £40 PCV valve and carbon canister / solenoid valve £15 Snorkel plastic surround £5 VR6 oil sump, not old and has a graze but purely an outer grace and hasn't deformed internally. I have the gasket too. £35 Another 4 inch to 3 inch adaptor silicone hose brand new by AST Technologies £5 Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted May 8, 2013 I'll take the decat please mate. Are you going to National Day? If so I could have it then, otherwise could you post? Quote Share this post Link to post Share on other sites
Rams 0 Posted May 8, 2013 Sure thing, its yours. Should be attending National Day. Decat now SOLD Quote Share this post Link to post Share on other sites
Rams 0 Posted May 8, 2013 More pictures added Quote Share this post Link to post Share on other sites
Rams 0 Posted May 8, 2013 For those who have asked, this is the adaptor, brand new, never fitted and black. I actually have 2 and the stainless hose clamps. Made by AST. Wide end 102mm narrow end 76mm Cheers Rams Quote Share this post Link to post Share on other sites
VWVW 1 Posted May 8, 2013 Hi Rams interested in the sump + Gasket. How much posted ? Quote Share this post Link to post Share on other sites
Rams 0 Posted May 9, 2013 (edited) To post out, £10 should cover it, is that ok with you? Now Sold Edited May 9, 2013 by Rams Quote Share this post Link to post Share on other sites
Rams 0 Posted May 14, 2013 Ecu now sold and sump. Have found another sump gasket if anyone needs one. Good condition Quote Share this post Link to post Share on other sites
VWVW 1 Posted May 14, 2013 Sump and Gasket received today cheers Rams Quote Share this post Link to post Share on other sites
dj b 10 Posted May 14, 2013 Will the MAF fit my 94 vr6? how do I know? thanks and sorry if its a dumb question Quote Share this post Link to post Share on other sites
Rams 0 Posted May 14, 2013 Sump and Gasket received today cheers Rams Jolly good, you can tell its quite new, will you paint it or protect it before you install it? Quote Share this post Link to post Share on other sites
VWVW 1 Posted May 14, 2013 Jolly good, you can tell its quite new, will you paint it or protect it before you install it? Thats the plan...Yes will give it a slight sand down and rust proof and paint it up Quote Share this post Link to post Share on other sites
Rams 0 Posted May 14, 2013 MAF now sold ---------- Post added at 10:05 PM ---------- Previous post was at 10:01 PM ---------- Oil pressure switch £3 plus delivery fully working order Quote Share this post Link to post Share on other sites
seanl82 23 Posted May 14, 2013 Ball sack, missed the boat on the sump and gasket......................:bonk: Quote Share this post Link to post Share on other sites
Rams 0 Posted May 15, 2013 Got another gasket if you need? Quote Share this post Link to post Share on other sites
Rams 0 Posted May 15, 2013 Dragon, do you need the inlet pipe as pictured or do you just need the small pipe coming off it to the PVC valve? I have both as the one pictured earlier in the add was a damaged inlet but the pipe coming off it was fine but pictured that one as they look the same and it was closest to me whilst i had my camera but this is the good inlet. Basically I can sell you just the pipe work instead of the inlet and I can sell the inlet separately. Cheers Rams Quote Share this post Link to post Share on other sites
Rams 0 Posted May 15, 2013 ECU and MAF posted out today. Chrome rocker cover and matching gasket available. I may even re polish it if I get board, just needs some wet and dry/autosol as all the work sanding and polishing has been done previously. Calliper carriers not sure what they fit but part number is listed. Quote Share this post Link to post Share on other sites
dragon 0 Posted May 15, 2013 Just the small pipe coming off it mate Quote Share this post Link to post Share on other sites
seanl82 23 Posted May 15, 2013 Got another gasket if you need? Is it an early type (fibre?) or late (rubber?), as I need the later type whichever it is mate. If so, how huch do you want posted? Cheers buddy! Quote Share this post Link to post Share on other sites
Rams 0 Posted May 15, 2013 It's a late one, from my 95 VR. Rubber type. Postage will need a biggish box to keep it flat... What would you be happy to pay? ---------- Post added at 6:15 PM ---------- Previous post was at 6:13 PM ---------- Just the small pipe coming off it mate Ten of your finest, delivery a few quid Quote Share this post Link to post Share on other sites
seanl82 23 Posted May 15, 2013 Is it Genuine or an OE Replacement? What would you be happy to sell for?? :norty: Quote Share this post Link to post Share on other sites
Rams 0 Posted May 16, 2013 Believe original, how would one tell? ---------- Post added at 2:47 PM ---------- Previous post was at 2:46 PM ---------- Set of standard injectors available for VR6, removed when I upgraded to 440's. £50 plus delivery for the lot Quote Share this post Link to post Share on other sites
stuarttaylor37 13 Posted May 18, 2013 PCV valve and carbon canister / solenoid valve £15 I'd like this pending reply to PM please Quote Share this post Link to post Share on other sites
dragon 0 Posted May 19, 2013 Hello Ram have you received my MSG on the part mate Quote Share this post Link to post Share on other sites
