Rams
VR6 - Random parts
Polished rocker cover with appropriate gasket, when I had it fitted it was gleaming so just needs so wet and dry/autosol to return the shine.
£50 plus delivery
Miltek sports de cat pipe with Lamba which I can't get out.
£25
Set of calliper carriers, they have been blasted and wet painted professionally in black, had them done and realised they didn't fit my car. Part number 5612/41211 and 5612/4 2191. If anyone knows what they would fit I'd appreciate it?
£45
OBD1 inlet pipe in perfect order
£15
OBD1 late ecu in perfect working order
£45
Audi TT 4 inch MAF and suitable AST silicone pipe adaptor
£40
OBD1 MAF complete with sensor, again, perfect working order
£30
Coolant Thermostat housing
£10
More parts to be added. The above are all without postage, so postage costs would be additional. Located in Bournemouth for those who wish to collect.
Continuing
Vr6 fuel pump sender and pump, runs quietly
£40
PCV valve and carbon canister / solenoid valve
£15
Snorkel plastic surround
£5
VR6 oil sump, not old and has a graze but purely an outer grace and hasn't deformed internally. I have the gasket too.
£35
Another 4 inch to 3 inch adaptor silicone hose brand new by AST Technologies
£5
I'll take the decat please mate. Are you going to National Day? If so I could have it then, otherwise could you post?
Sure thing, its yours. Should be attending National Day.
Decat now SOLD
For those who have asked, this is the adaptor, brand new, never fitted and black. I actually have 2 and the stainless hose clamps. Made by AST.
Wide end 102mm narrow end 76mm
Rams
To post out, £10 should cover it, is that ok with you?
Now Sold
Edited by Rams
Ecu now sold and sump.
Have found another sump gasket if anyone needs one. Good condition
Will the MAF fit my 94 vr6? how do I know? thanks and sorry if its a dumb question
Sump and Gasket received today cheers Rams
Jolly good, you can tell its quite new, will you paint it or protect it before you install it?
Thats the plan...Yes will give it a slight sand down and rust proof and paint it up
MAF now sold
---------- Post added at 10:05 PM ---------- Previous post was at 10:01 PM ----------
Oil pressure switch £3 plus delivery fully working order
Dragon, do you need the inlet pipe as pictured or do you just need the small pipe coming off it to the PVC valve?
I have both as the one pictured earlier in the add was a damaged inlet but the pipe coming off it was fine but pictured that one as they look the same and it was closest to me whilst i had my camera but this is the good inlet.
Basically I can sell you just the pipe work instead of the inlet and I can sell the inlet separately.
Rams
ECU and MAF posted out today.
Chrome rocker cover and matching gasket available. I may even re polish it if I get board, just needs some wet and dry/autosol as all the work sanding and polishing has been done previously.
Calliper carriers not sure what they fit but part number is listed.
Got another gasket if you need?
Is it an early type (fibre?) or late (rubber?), as I need the later type whichever it is mate. If so, how huch do you want posted? Cheers buddy!
It's a late one, from my 95 VR. Rubber type. Postage will need a biggish box to keep it flat... What would you be happy to pay?
---------- Post added at 6:15 PM ---------- Previous post was at 6:13 PM ----------
Just the small pipe coming off it mate
Ten of your finest, delivery a few quid
Believe original, how would one tell?
---------- Post added at 2:47 PM ---------- Previous post was at 2:46 PM ----------
Set of standard injectors available for VR6, removed when I upgraded to 440's.
£50 plus delivery for the lot
