VR6 Gar 10 Posted February 11, 2014 Cheers Ollie, pretty sure it went on straight, although it is off centre in the pic. With deciding not to bother with a snap off boss I ordered a new Carbon horn press to replace the cracked one, so even if it is off slightly I can adjust when fitting. Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted February 11, 2014 I love this car Gareth! Not so keen on the fast and furious gauges. But each to their own. Quote Share this post Link to post Share on other sites
coullstar 0 Posted February 12, 2014 Lol, thats the same wheel that was in it when I got it. Ollie, its better to have them than not, you need to keep an eye on everything when running a car like this and they pillar mounted ones are perfect for just glancing at espeically when your motoring along. Quote Share this post Link to post Share on other sites
OllieVR6 0 Posted February 12, 2014 coullstar said: Lol, thats the same wheel that was in it when I got it. Can you remember who you sold it to? I've just checked my PM's and I bought it from Hofmiester. Quote Share this post Link to post Share on other sites
coullstar 0 Posted February 12, 2014 It was a local guy so not the same one. Quote Share this post Link to post Share on other sites
VR6 Gar 10 Posted February 15, 2014 It wasn't straight after all.:bonk: Bit of a pain as it needs fully reassembling before its straightness can be checked which is time consuming. For now I have just moved it a spline then will see if its straight when I take it out later. Got the new horn fitted though. Quote Share this post Link to post Share on other sites
robrado974 1 Posted February 15, 2014 Nice , i had the same one in my car . Quote Share this post Link to post Share on other sites
coullstar 0 Posted February 17, 2014 Seen this? Quote Share this post Link to post Share on other sites
VR6 Gar 10 Posted February 17, 2014 No, how did that come about? Guessing the pic is from when you owned it? Quote Share this post Link to post Share on other sites
coullstar 0 Posted February 17, 2014 Nope, must have been Caol. Just looked again and its at Aberdeen harbour entrance. Some silly comments on it. Quote Share this post Link to post Share on other sites
VR6 Gar 10 Posted February 18, 2014 Mostly love though, it has over 1000 likes. Never going to be liked by everyone. Had to reply to the idiot who drives a Fiat Coupe and had the cheek to call my car ****,lol. Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted February 18, 2014 Jim said: It's quite a weird thing with some of these cars having changed hands on the forum several times, you sort of forget who owns them but also gets confusing when you see cars that previously lived miles apart, in different regions.. I was momentarily looking at that thinking 'Did coulstar drive all the way down from Scotland, and meet up with Cazza?' before of course realising that neither car belongs to those folks any more :) :lol: definitely a bit weird, especially with the gearbox as well! Car's looking great Gareth 8) gearbox still ok? Quote Share this post Link to post Share on other sites
VR6 Gar 10 Posted February 18, 2014 Still silky smooth. Going to be a shame to remove it but I will have to find another box for the diff to go back into before dropping it off with my mechanic to swap over. Quote Share this post Link to post Share on other sites
VR6 Gar 10 Posted February 19, 2014 (edited) Today I got this. Only a cheap ebay job, cost £18 delivered and is of fairly good quality considering price. Came with some brackets I didn't need and also had some mounting points that needed cutting off with a dremel. In order for it to sit where I wanted it the rear ash tray, which was not used anyway, was sealed shut with a couple of small blobs of PU flex. A bit more PU was used on the underside and a couple of self tappers screwed through the centre console. The tunnel cover already had a small piece of plastic missing where it meets the ash tray, so I wasn't bothered about putting a couple of holes through it. Will also be possible to remove it by peeling off all the adhesive should I so wish. Having seen how high the passat/mk4 golf arm rest sits and how much extra work was involved in getting it to fit nicely I am glad I went with this option. Edited February 19, 2014 by VR6 Gar Quote Share this post Link to post Share on other sites
VR6 Gar 10 Posted February 20, 2014 (edited) Just fitted new Meyle track rod ends and ball joints while the weather wasn't too bad. Only got rained on once. :cheers: Just sat in Protyre while they set the toe up. Edit, both lock nuts are completely seized, so new inner arms required. Edited February 20, 2014 by VR6 Gar Quote Share this post Link to post Share on other sites
Roger Chatfield 0 Posted February 23, 2014 Loving the armrest mate, looks OE, did you go to Protyre in Plymouth??, if you did you should have popped round for a brew mate. Rog. Quote Share this post Link to post Share on other sites
VR6 Gar 10 Posted February 24, 2014 Roger Chatfield said: Loving the armrest mate, looks OE, did you go to Protyre in Plymouth??, if you did you should have popped round for a brew mate. Rog. Cheers Rog, was Pro tyre on Marsh Barton. Don't get down Plymouth very often, furthest I get is some friends who live in Plympton. Quote Share this post Link to post Share on other sites
VR6 Gar 10 Posted March 8, 2014 After the locking nuts being too stuck to undo I replaced the inner rods. Dead easy and didn't take long at all. Today I replaced all the rear brakes. New Mtec dimpled and grooved discs, SKF bearings, ABS rings and Ferodo Premier pads. Gave the rears a bleed and bled the clutch too. Will give the fronts a bleed at some point soon. Decided to try and reduce exhaust drone a bit further by removing the boot floor carpet and cutting some domestic carpet underlay to shape and fixing it to the underside. Quote Share this post Link to post Share on other sites
VR6 Gar 10 Posted March 26, 2014 (edited) Put the car through its MOT a couple of weekends ago. Only a few advisories for brake pipes which have now been treated with Hammerite krust paint. Replaced the cheap Pioneer 6x9s with some Infinity ones I had kicking around. While there, having the stealth material up, I added some carpet underlay in the recesses on the parcel shelf to aid sound insulation further. Today these arrived. Konig K5000 seats, the kind mk4 R32 seats are fashioned on. Wasn't seriously looking to change the interior just yet, but I saw them on ebay and got them cheap, considering they are £960 a pair new I couldn't miss out. Subframes have been ordered and will take about 2 weeks as they are custom built and fit the original runners. Plan on getting a leather dye kit and making the silver bits black and at some point trying to find leather door cards and rear bench and arm rest. Sat in them and they are ridiculously supportive and fit me perfectly, far better than Recaros. There are a few small blemishes, such as cracked harness plastics, but I recon I could get hold of these from Konig at some point if I so wish. Wheels had got pretty manky so i dropped them off at SWWR for a freshen up on Monday. 2 of them were out of true, so the ride should also be improved when back on the car. Edited March 26, 2014 by VR6 Gar Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted March 26, 2014 Nice find, be careful using hammerite on the brake pipes just replace them heard too many stories of brakelines just giving up and your left with no brake pedal Quote Share this post Link to post Share on other sites
VR6 Gar 10 Posted March 26, 2014 They only had very slight surface rust, will keep an eye on them but they aint going to break anytime soon. Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted March 26, 2014 Thats cool mate im sure you know what your doing. Quote Share this post Link to post Share on other sites
coullstar 0 Posted March 26, 2014 Emissions pass okay? Quote Share this post Link to post Share on other sites
VR6 Gar 10 Posted March 26, 2014 My MOT man is very friendly and didn't even bother checking it, lol. Quote Share this post Link to post Share on other sites
Roger Chatfield 0 Posted March 26, 2014 I'm liking those seats, very nice, I know what you mean about Recarro's, I had them in my DC5 Integra and while they are very supportive they are just not that comfortable on a long journey, the leather seats in my storm are the best seats I've ever sat in, so comfortable. I can't car manufacturers use steel for their brake pipes, there must be a reason but why the hell didn't they use copper in the first place. Rog. Quote Share this post Link to post Share on other sites
