dalhalvaig 0 Posted May 26, 2013 I've a cracked windscreen. Prior to getting it changed I had a look at the condition of the body round the screen behind the seal. The NS A-pillar looks good, there's a bit of rust (NS and OS) where the roof channels meet the screen, qbut the OS A-pillar has some nasty rust including a couple of holes right through. The exposed outer is OK and inside behind the A-pillar trim is good too. I'm sure this won't be the first time this has happened. So I'm looking for some advice on how to repair it. I'm looking at it being repaired by a bodyshop as I realise it will need some welding. Can you get any replacement panels? Is it straightforward to cut out the rusted parts, cut some new steel and weld it in? I'm thinking of repairing even although it will cost a lot compared to the value of the car, but it's probably less than the depreciation on a new car. Any comments or advice received. Quote Share this post Link to post Share on other sites
robrado974 1 Posted May 27, 2013 I had mine done , the pillars were £60 a side from Vw , not sure if they still have them , it's not something that gets replaced everyday , so you should be ok Rob Quote Share this post Link to post Share on other sites
KIPVW 0 Posted May 27, 2013 I had a couple of sections cut out and replaced on my Nugget due to this too, a fairly straight forward task for a good bodyshop. Quote Share this post Link to post Share on other sites
Timbo 0 Posted May 27, 2013 Some pictures would help understand the extent of the problem. Quote Share this post Link to post Share on other sites
dalhalvaig 0 Posted May 27, 2013 Thanks for that. How recently did you have them done? Quote Share this post Link to post Share on other sites
robrado974 1 Posted May 27, 2013 Mine were replaced around 18 months , two years ago ? . Even if out of stock like Paul says a good body shop will be able to sort it for you . Quote Share this post Link to post Share on other sites
dalhalvaig 0 Posted May 27, 2013 Thanks, I'll try the local VW dealer and see if they have parts or can get them. The body shop I'm talking to contacted their supplier, but they could get any. 18 months is not that long ago, so hopefully... Also how do you figure out if VW classic/heritage has parts? I'll get some picks up but TBH it's quite hard to see as the screen is still in place. Quote Share this post Link to post Share on other sites
dalhalvaig 0 Posted May 27, 2013 Here are some pics. It's quite hard to see the damage as the screen is still in place Quote Share this post Link to post Share on other sites
Timbo 0 Posted May 27, 2013 Woah yep, that definitely needs replacing. If you can't get genuine panels a bit chopped out of a breaker will do the job. Quote Share this post Link to post Share on other sites
dalhalvaig 0 Posted May 28, 2013 Rob - I contacted the local VW dealer today and they say that the part was discontinued in 2011, so looks like you got the last of them. The guy reckoned that the part run from the sill, up past the door hinges, up the A-Pillar, then along the roof. Is this the part you used, or did you get a part panel? Anyway VW don't seem to have any unless someone has one squirreled away. A pity as they were £86 inc vat. I'll wait to see what the body shop come up with. Quote Share this post Link to post Share on other sites
robrado974 1 Posted May 28, 2013 That's a bummer , as far as I'm aware they just got the pillars ? . Have to see what the body shop or chaos can come up with then . Quote Share this post Link to post Share on other sites
dalhalvaig 0 Posted July 21, 2013 Hi all First of apologies for no update...but it is now all fixed. I went to these guys M-Teq Body Repairs in Alexandria, west of Glasgow. http://www.m-teqbodyrepairs.co.uk/ They were recommended by a friend and I'm pleased with the work they did. Oliver (Ollie) Murray runs the place, has a great attitude and is into his VWs and Audis which helps a lot. They cut out the corroded metal and welded in new steel. Then painted. And I used FGA for the windscreen. They work with M-Teq and were happy to do the double trip - screen removal and then back for refit after repair. Again very helpful. So thanks for the offer of parts etc, but now sorted. Cheers D Quote Share this post Link to post Share on other sites
easypops 8 Posted July 21, 2013 Good to hear its sorted mate, we'll need to meet up at some point.......would like to find out rough costings for a job like this :) Quote Share this post Link to post Share on other sites
