Hofmiester 10 Posted October 22, 2013 Hi guys, Bought some lamin-x to protect my front indicators and fogs. Fogs were easy but the indicators have raised text on them. Will that be ok to Appy over or do I need to sand the text off? Cheers Ron Quote Share this post Link to post Share on other sites
seanl82 23 Posted October 22, 2013 You'd be better off trimming the text off with a stanley blade, but if you heat the lamin-x first with a hairdryer/heatgun, it should mould itself around the text a fair bit when it cools. Its not perfect, but not really noticable. Seeing as they are so small its worth a go before cutting it off, and you won't waste too much doing a repeater. Quote Share this post Link to post Share on other sites
dragon green 6 Posted October 22, 2013 Use the back of a Stanley blade,don't try and rush it,then sand it smooth,finally with a very fine paper,wash lens with water and washing up liquid.Dry with a micro-fibre towel,as said heat is good,I only used heat on the edges ! I noticed a small crack on one of my fogs when I washed it last weekend,Lamin-x didn't save that ! Good luck,take your time,and don't forget to post pics Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted October 22, 2013 (edited) Hairdryer is your friend for sure. The misses may not like it I didn't take the letters of mine have a look on Sunday if u want bud Edited October 23, 2013 by davidwort Quote Share this post Link to post Share on other sites
