robrado974 1 Posted November 2, 2013 What kind of screw head is it , if got two small pozi heads in there but can't turn it , I don't want to knacker the head up . I've had a torch up there to have a look but my eyes are straining to see it ! Thanks Rob Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted November 2, 2013 It is a pozi head screw but i found using a flat head better for gripping the screw. I assume your using small watchmaker type screw drivers as they work best with the room you have Quote Share this post Link to post Share on other sites
robrado974 1 Posted November 2, 2013 Looks like someone has had a go before , I've held a mirror up to the head and it's not the best to be honest . To make matters worse I plugged the new switch in to try it and it still won't start . Quote Share this post Link to post Share on other sites
easypops 8 Posted November 2, 2013 Did you have your key in the ignition? Quote Share this post Link to post Share on other sites
robrado974 1 Posted November 2, 2013 (edited) Yes I did , it's just turning over and backfiring . I'm so close to breaking the car now !cant believe out of a possible 15 screwdrivers not one of them will undo the screw , it must be so tight . Edited November 2, 2013 by robrado974 Quote Share this post Link to post Share on other sites
seanl82 23 Posted November 2, 2013 Smash it off Rob. Thats what I had to do in the end. It'll have no stress keeping it tight then so should come out easily. Quote Share this post Link to post Share on other sites
robrado974 1 Posted November 2, 2013 Bit worried about breaking something if I wack it Sean . By fitting the new one in at least I've eliminated the switch . Rob Quote Share this post Link to post Share on other sites
vw rule 19 Posted November 2, 2013 Hello Rob, I replaced my ignition switch around 6 years ago now. What I used was a small 1/4"(6mm) combination spanner, and super glued a small Philips screw driver end bit, in to the ring spanner end. LIKE THIS [ATTACH=CONFIG]76214[/ATTACH] [ATTACH=CONFIG]76215[/ATTACH] For me it worked a treat as I was able to get to the small retaining screw, from the top whilst sat in the drivers seat, it took me around 3 mins to get the screw out, as your only able to turn the screw small movements at a time, and about the same time for it to be screwed back in. The steering column was adjusted to it's lowest level, and both the top / bottom steering column cowlings were removed. Hope this helps. Si Quote Share this post Link to post Share on other sites
davidwort 0 Posted November 2, 2013 I've a bent mid sized flat head watch makers screwdriver specially for the job :) works fine every time, screw is not normally very tight as it's short and the head is sat on the plastic of the switch Quote Share this post Link to post Share on other sites
Talltorrac 10 Posted November 2, 2013 I also used a watch makers/precision screw driver - the difficult part was holding the driver in place and twisting it - I used one of those drivers with the free moving top of the screw driver so I could push and twist at the same time and used needle nose pliers to turn whilst I held in place with the other hand. Wasn't very tight at all and was really surprised as all the information on here suggested I would in for a difficult job Someone the other day told me that trapping a rubber band between the screw and the screw driver head works for extra grip when the head has been buggered! Quote Share this post Link to post Share on other sites
robrado974 1 Posted November 2, 2013 Thanks for the replys , really appreciate it .i tried the pliers on the watch makers screw driver , also took of under tray and cowl . I think someone's had a go before because the head is not the best . I tried many drivers but none seemed to fit . Rob Quote Share this post Link to post Share on other sites
vw rule 19 Posted November 2, 2013 Hope this hepls mate. http://the-corrado.net/showthread.php?t=47241&highlight=ignition+switch+removal http://the-corrado.net/showthread.php?t=82997&highlight=ignition+switch Hope you sort it mate. That little screw can be a swine, you will get there it just takes a little time. Si Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted November 2, 2013 Rob, as I said in the other thread, and as Sean has mentioned here, break it off! Get a flat bladed screwdriver and hammer and give it a few whacks. Look at your new switch and you'll see the tiny plastic bracket you need to break off the existing one. Quote Share this post Link to post Share on other sites
robrado974 1 Posted November 2, 2013 Hello Rob, I replaced my ignition switch around 6 years ago now. What I used was a small 1/4"(6mm) combination spanner, and super glued a small Philips screw driver end bit, in to the ring spanner end. LIKE THIS [ATTACH=CONFIG]76214[/ATTACH] [ATTACH=CONFIG]76215[/ATTACH] For me it worked a treat as I was able to get to the small retaining screw, from the top whilst sat in the drivers seat, it took me around 3 mins to get the screw out, as your only able to turn the screw small movements at a time, and about the same time for it to be screwed back in. The steering column was adjusted to it's lowest level, and both the top / bottom steering column cowlings were removed. Hope this helps. Great idea that . I found it easy to get the driver on the screw , it's undoing it that's hard Rob Quote Share this post Link to post Share on other sites
vw rule 19 Posted November 2, 2013 Yeah that's it Rob, it will unscrew it just takes a few minutes, as you can only turn it in small movements. Si Quote Share this post Link to post Share on other sites
robrado974 1 Posted November 2, 2013 (edited) Rob, as I said in the other thread, and as Sean has mentioned here, break it off! Get a flat bladed screwdriver and hammer and give it a few whacks. Look at your new switch and you'll see the tiny plastic bracket you need to break off the existing one. Ok will give it a go ! Edited November 3, 2013 by robrado974 Quote Share this post Link to post Share on other sites
robrado974 1 Posted November 3, 2013 Done it , thanks for all the info and help Rob Quote Share this post Link to post Share on other sites
