stevec14 10 Posted November 9, 2013 Hi All Has any one done this mod to they're Corrado G60 dash clocks? Looking to replace some bulbs in my clocks(poorly lit up) And found some led type on ebay. Has anyone purchased these and are they a direct fit? And what colour is best suited to the dash clocks for standard+ look white or green? Thanks Steve Quote Share this post Link to post Share on other sites
Kempy 0 Posted November 11, 2013 I've done blue ones. Quote Share this post Link to post Share on other sites
geoffersmaher 10 Posted November 12, 2013 Easy to replace , just bought some ebay specials myself when I did it, went for green as I like everything to look as it should just a little better And it does Quote Share this post Link to post Share on other sites
Yandards 0 Posted November 12, 2013 I stuck with green, its a brighter stronger green but the white LED is the wrong colour temperature. Works best on the clock and mileage display screen as those are very poorly lit, the 3 x lights the illuminate the fuel/temp, speed and rpm gauges don't benefit as much. Quote Share this post Link to post Share on other sites
geoffersmaher 10 Posted November 12, 2013 I noticed a big difference in mine. Ill dig up a pic Yandards said: I stuck with green, its a brighter stronger green but the white LED is the wrong colour temperature. Works best on the clock and mileage display screen as those are very poorly lit, the 3 x lights the illuminate the fuel/temp, speed and rpm gauges don't benefit as much. Quote Share this post Link to post Share on other sites
fla 9 Posted November 12, 2013 (edited) Also did mine in blue - best to use 3x SMDs for each portion of the clocks, so 9 SMDs in total required. Edited November 26, 2013 by fla Quote Share this post Link to post Share on other sites
geoffersmaher 10 Posted November 12, 2013 [ATTACH]76391[/ATTACH] Quote Share this post Link to post Share on other sites
stevec14 10 Posted November 12, 2013 Thanks All for replies. Green does look very OEM+. Will try white ones but don't think they will look half as good! Steve Quote Share this post Link to post Share on other sites
stevec14 10 Posted November 14, 2013 Here's some pictures with white leds 10 for £4.79 ebay. And yes that was my actual MPG on a run home tonight on the MFA. Don't know if it's accurate haven't calculated it out yet. But car is running a lot better since Thermostat changed. Quote Share this post Link to post Share on other sites
geoffersmaher 10 Posted November 25, 2013 the white looks nice i must say, but for me a bit to pale , i like that dark oem green look where they the strait swap kind or solder kind? Quote Share this post Link to post Share on other sites
Album56 0 Posted November 30, 2013 I notice that some cars have red needles on the clocks & some white, my 92 G60 has white & after replacing the temp/fuel gauge temporarily with a red needle one, while faulting the temp gauge, it is noticeable that the white needles show up much better at night. also the oem bulbs for lighting the clocks stand about half inch up from the base & are often replaced incorrectly with squat ones which dont line up properly with the green cellophane giving a very dim light. Hope this helps Quote Share this post Link to post Share on other sites
