STORM 2
Tailgate gap fixed
Hi
I posted a thread earlier regarding an uneven gap on the tailgate when shut - Afew others had this problem and suggested the hinges could be going.
Anyway, I fiddled around with the striker plate which adjusts quite freely and NOW there is no longer a gap. Seeing as this is just a five minute job I thought it would be worthwhile posting just in case other fools like me spend months figuring it out :oops: :oops:
Wow that sounds like something the reliable boys at Karman should have dealt with at the factory!!
Shock horror! :)
I was thinking of sending it back to them to do it properly..........................
I bet you undid the two allen bolts and moved the latch plate to the right?
Most Cs I've seen have a large gap on the right side.
My gap was on the left - so I loosened the two allen bolts and moved down and to the left
Needs a bit more power to click shut now though...........
Yeah that'll subside over time mate.
I think the tailgate alignment was done on a Friday afternoon at the Karmann factory :roll:
